08-14-2019, 12:48 PM | #1 |
481
Rep 1,468
X-drive midpipe
Is AWE the only midpipe that fits an xdrive? Looks like it doesnt have a resonator on it. Are there any with resonators?
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
08-16-2019, 05:06 PM | #2 |
993
Rep 1,934
Really no benefit in buying midpipes, unless it's the split and remerge type like Akra. Remove the resonator on your oe midpipe for the same effect, or leave it (which is far better for drone)
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
08-16-2019, 05:34 PM | #3 |
Check out my Youtube @n55david!
1297
Rep 3,536
Drives: 2017 m240i, 2015 X3 x35i
they all fit the xdrive
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
09-03-2019, 03:27 PM | #5 |
26
Rep 93
I test fit one and while it does fit, it does not line up properly with the MPE or stock exhaust. Learned that the hard way and had to send it back. Went with a res delete on my stock OEM pipes..
09-03-2019, 03:28 PM | #6 |
481
Rep 1,468
09-03-2019, 03:44 PM | #7 |
26
Rep 93
The AWE midpipe was not lining up properly, the angle was way off and the only way to make that work would have been to weld.
As far as any other midpipes - I'm not sure why they say they are from RWD only (Dinan for example) but I haven't had any experience with them. The only thing I know is that if you want the AWE midpipe, you're probably best getting the muffler as well. |
