N43 injector coding
08-14-2019, 08:22 AM | #1 |
Rep 5
Drives: F30 BMW 320i M Sport xDrive
N43 injector coding
Hi everyone.
I have a 318i N43B20 engine and it misfires in the morning cold start after about 20 mins to 30 mins it then goes off, I fear this is a fuel injector issue as I've replaced the spark plugs and swapped the ignition coils and it misfired the same cylinder. After doing a bit of digging I've heard you have to re-code the injectors if you replace them but what about if you just take one out to inspect it and put it back or swap two around? Do you need to code them then? I'm slightly reluctant to take it to a garage immediately because they'll charge and arm and a leg prefer to know that the issue is with the injectors before I get them replaced and coded. |
08-14-2019, 09:49 AM | #2 |
729
Rep 1,815
Yes, you will need to code them AND replace the injector seals. My 118i also has the n43 and there was a recall done on the injectors a few years back, check with your dealer and see if your car was also on the list.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
