About to pull the trigger on buying highly modified BMW
08-13-2019, 06:03 PM | #1 |
8
Rep 73
I have been searching for a few weeks for a Montego Blue 6 speed 335i, and finally found one that is only an hour away from me. I am having a PPI done on it tomorrow, and will likely be going to see it this weekend. This thing has been highly modified, but it seems to have been done with quality parts:
RB Next Gen Turbos 3.5 bar MAP sensor Silicone inlets/outlets VRSF catless downpipes VRSF 7.5" FMIC ETS charge pipe BMS DCI MSD81 ECU Upgrade (It is manual swapped, so opted for new manual ECU) MHD Tune by Omar Stage 2.5 LPFP ADe Port Injection kit AIC split second controller Mfactory Single Mass Flywheel Spec 3+ clutch NGK iridium 2 step colder plugs Index 1 injectors It is also tuned for e85, but he said it could run on other gas with an Ethanol Content Sensor and adjusted tune. It also has new bosch coils installed. The guy seemed very upfront about the build and had no problem telling me all about the build and the previous owners. I only have 2 things that I am concerned about. The first is that it is originally an auto car, so I am worried that I will have electrical issues in the future and it has the auto diff so i'll probably want to swap that out. However, with the upgraded ECU I am thinking that shouldn't be a problem, but I was hoping that someone on this forum with a little more wisdom on this platform could tell me whether or not that really is something to worry about. Secondly, the car has about 172k miles. Water pump, fuel regulator, VANOS, and all the annoying leaky gaskets have been addressed. I am just concerned with the life of the engine especially with the power it is putting out. I believe he is currently running low 20 psi. I am fine with having to eventually rebuild the engine at some point, but I don't want it to die on me a month after I purchase it haha. His asking price is 9k, but he is negotiable. Now, this will be a project car that I will be doing all work on myself, so is this car worth buying? What would be a good price to counter with? Also, the guy doing the PPI for me said he could do a compression test for an extra $150, is it worth it? Thanks! Last edited by wes.myers; 08-13-2019 at 06:11 PM.. |
08-13-2019, 06:13 PM | #3 |
38
Rep 97
Do it.....aren't all those mods worth 9k in labor alone? If it goes t*ts up you can part it out and get your money back but then that's the worst-case scenario. Live a little
BMW e93 335i Cabriolet M Sport. Sapphire Black, N54, Michelin Pilot Sport 4s
wes.myers8.00 |
08-13-2019, 06:56 PM | #4 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
9k isn't that bad.. I'd probably risk it if you have money burning a hole in your pocket. also.. Omar is tuning now? Lol
but also... good luck.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
08-13-2019, 06:59 PM | #6 |
8
Rep 73
Wouldn't necessarily say I have money burning a hole in my pocket, but I am willing to invest in this project haha
08-13-2019, 08:46 PM | #10 |
8
Rep 73
I don't believe it was tracked, but I can ask.
It's a 2007 Don't know how old he is, but I'd guess in his mid 30s. He is getting rid of it because his stage 3 roush build is almost done at the shop and he wants to focus all his time and money on that. |
08-13-2019, 09:07 PM | #11 |
101
Rep 308
I wouldn't worry about the rear diff. It's a common swap between manuals and autos, since you have an auto rear diff, I would say it's a + for you. 3.08 vs 3.46 for the auto I believe.
08-13-2019, 09:09 PM | #12 |
8
Rep 73
08-14-2019, 10:00 AM | #13 |
1013
Rep 1,268
I have an 07 (bough in 10/06) 335I Manual with 170K miles and the car is running strong, no issues other than the standard maintenance issue which it sounds like this car already addressed. There are plenty of examples of N54 with 200K+ miles and engine can handle it. I do doubt the car is putting down 500+ to the Wheels, granting I not kept up on the turning but all the tunes I use to see was in the 400+ range.
The real question is how much abuse did the owners put onto the engine. As it was pointed out, you could always part out the car for the cost of the car if things do not go well. |
wes.myers8.00 |
08-14-2019, 10:28 AM | #14 | |
8
Rep 73
Wolf 3352340.50 |
08-15-2019, 09:12 AM | #16 |
8
Rep 73
So PPI results came back in:
Cons: There are a lot of transmission codes that were scanned, looks like it isn't reading a lot of the sensors that would be on an automatic transmission. Not sure what the solution is, but considering the car isn't originally manual, I don't think I'd even consider buying unless those codes were dealt with. Rear bumper has a crack in the paint from minor impact. Front bumper is slightly warped, and there are a ton of scrapes on the bottom. The passenger side front bumper has paint completed scraped off. The splash guard has been completely ripped off from it running over a curb. Hood is faded and will likely need new paint. Headlights are faded. oil filter housing & oil cooler thermostat gasket needs to be replaced. Transmission output shaft seal will need replacement (although they said the leak is minimal). oil change needed. Battery is also weak (660 cold cranking amps). Compression test - one of the cylinders gave slightly lower compression. They figured that it may be from dirty valves. So they are cleaning the valves right now and will be retesting to see if it solves the issue. Pros: Brakes look great (front is almost brand new). Tires look good. Rear suspension looks good. Front suspension - brand new lower control arms x4. Serpentine belt recently replaced. |
08-15-2019, 09:45 AM | #17 |
641
Rep 1,245
They are walnut blasting the valves and retesting the compression?
Thats going to be a hell of a PPI bill if you dont buy it. If you dont want to deal with issues, stop shopping for someone elses project with major work done and a transmission swap. Seems obvious enough Problems dont seem drastic enough to walk away. If you dont care about the power, then find a stock one, but theres gotta be a reason youre considering a highly modified car, most likely because you want those parts.
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50 11.61 @ 117.5 New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets |
08-15-2019, 09:59 AM | #18 |
8
Rep 73
I'm not paying for the walnut blasting (although they may just be doing a chemical clean).
I don't mind dealing with issues, but I want to know what the solution is to issues like this considering that I didn't do the work on the swap and want to at least be confident that everything is working as it should. I am obviously not super familiar with this platform. So I am hoping that I can rely on y'alls knowledge and expertise to ensure that I am making the most informed decision when it comes to buying a 335i. |
08-15-2019, 02:52 PM | #19 |
598
Rep 1,343
Do you think people highly modify their car to drive to groceries staying within the speed limits? Why is this fella selling it? I'd never touch a modified car let alone ones with issues.
$2k starting price. Rip out the mods and sell them to the people here. And laugh yourself to the bank. |
08-15-2019, 04:07 PM | #20 | |
8
Rep 73
08-15-2019, 04:10 PM | #21 | |
3973
Rep 7,215
delete option S205A, default code the car - done, no more errors. |
Thorin117.50 |
Tags |
335i, buying, modifications, mods, n54 |
