08-13-2019, 09:45 AM | #1 |
3510
Rep 2,044
Using "Camber Correction" Hubs?
Hello BMW Experts!
Has anyone put in these correction hubs to get a little front camber, instead of using the F80 LCA? - I imagine the hubs come with wheel bearings. True? - Why do the hubs have different names, ie: "Carrier" (stock), "Pivot Bearing" (correction, left), "Swivel Bearing" (correction, right)? https://www.realoem.com/bmw/enUS/sho...diagId=31_0956 TIA! Murf |
08-13-2019, 01:15 PM | #2 |
432
Rep 785
https://f30.bimmerpost.com/forums/sh...1090804&page=8
I just posted this in another thread last night. Looks like one guy polo08816 did do it but I don't know if he's still active on the forum. |
08-20-2019, 06:06 AM | #5 | |
1610
Rep 3,947
The hubs do not come with wheel bearings but if you have some decent mileage on your original bears it might not be a bad time just to replace it while you're in there. As for the different names, just make sure it says "-30min" so you'll get more negative camber. One thing to keep in mind about camber correction hubs is that it will change the angle of the wheel in relation to the strut so the inner edge of the tire will be slightly closer to the strut. Camber plates don't change that relative angle, however, camber plates aren't as good for daily driving compared to camber correction hubs. |
08-21-2019, 05:20 AM | #6 |
3510
Rep 2,044
Thanks Polo,
I appreciate the feedback. Yes, with the bearings coming in that big hub assembly, maybe my old bearings can be used. I was thinking hammer out the bearing, then the race.... New hub/bearings are ~$100. - $200. ea. Did you do the work yourself? Murf |
08-21-2019, 06:42 AM | #7 | |
1610
Rep 3,947
I didn't bother to separate the old bearings from the old hub assembly. But it basically bolts to the hub assembly. An air chisel should be able to separate that pretty quickly. |
08-21-2019, 07:49 AM | #8 |
716
Rep 913
Drives: '17 F22,15 E84 M Sport,02 R53
I went the camber plate route on my daily driven M240i no issues drives 70 miles every day. That being said I would highly recommend you put in new bearings, not worth the little bit of $$$ saved to have to redo it if you experience bearing failure.
08-21-2019, 09:54 AM | #9 |
3510
Rep 2,044
08-21-2019, 12:00 PM | #10 |
20
Rep 99
I wonder why BMW makes camber correction hubs that induce additional positive camber? Along with the correction hubs, -30 min, there are ones offered for +30 min. Weird.........would it be for cars that are lowered big time?
08-21-2019, 03:24 PM | #11 |
1610
Rep 3,947
Yes, new bearings for me.
https://www.fcpeuro.com/BMW-parts/33...&b=5&d=3584&v= I could have sworn that I used SKF bearings when I did mine because they were substantially less expensive than BMW bearings, but that doesn't seem to be the case right now. Perhaps for the weirdos that want to install an aftermarket offroad lift kit on their BMWs. No idea. |
08-21-2019, 04:13 PM | #12 |
3510
Rep 2,044
Furious Method found these Meyle hubs for $106. ea:
https://www.oembimmerparts.com/Searc...ch=31206876840 The correction carriers look to be over $275. ea. Add a groovy bushing or two.... Murf Last edited by Littlebear; 08-21-2019 at 04:21 PM.. |
09-12-2019, 03:33 PM | #13 |
518
Rep 891
They're for the folks in collision repair who have bent subframe mounting points to deal with but the insurance company wouldn't pay out to pull the motor to fix it at the source.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
10-02-2019, 12:11 PM | #15 | |
809
Rep 1,597
10-03-2019, 10:23 AM | #16 |
1610
Rep 3,947
10-03-2019, 10:32 AM | #17 |
809
Rep 1,597
