15k+ worth of N54 e90/e92 parts, FULL LSD SWAP & MORE Parting out built e92 66k miles
08-12-2019, 06:11 PM | #1 |
Rep 5
call or text or message me about the parts 9136010443 just message about pricing! Also got a lot of parts I'm forgetting let me know if you need something
PARTS LIST #=PART NUMBER ES= ECSTUNING T= TURNER MOTORSPORT all parts have 10miles or less on them turbos went out during tuning LS swapping selling the motor and trans to only 66k miles on then just walnut blasted selling brand new index 12 injectors to have 10 miles on them also two sets of motiv twin disc clutches in et and one sst both have like 5 miles on them Inlets and outlets 2011 M3 LSD DIFFERENTIAL (3.15 RATIO) 2011 M3 HALF SHAFTS (LEFT AND RIGHT) 2011 M3 DRIVESHAFT CUSTOM TO FIT E92 MANUAL 335I ALREADY!! READY FOR INSTALL FULL LSD SWAP BOLT IN FRONT OXYGEN SENSOR BANK 1 ES#: 2580855 FRONT OXYGEN SENSOR BANK 2 ES#: 2580856 IGNITION COILS #6 OF THEM ES: 2919787 TMS OIl CATCH CAN BMW 335I WATERPUMP HIGH FLOW FUEL PUMP - 255LPH ES#: 2189784 MOTIV TWIN DISC CLUTCH ET - BMW N54 1300 TQ CAPACITY MOTIV TWIN DISC CLUTCH SST - BMW N54 1000 TQ CAPACITY MOTIV THROW OUT BEARING MOTIV PILOT BEARING X2 ECS PERFORMANCE CLUTCH FORK PIVOT PIN ES#: 2992391 FLYWHEEL BOLTS 8 OF THEM ES#: 20401 X2 CLUTCH FORK LEVER ES#: 41235 ALUMINUM BOLT SET FOR THE TRANSMISSION 5 OF THEM ES#: 2792706 X2 BMW CLUTCH PRESSURE PLATE BOLTS (8x16MM) 8 OF THEM #: 07119906045 X2 BMW ACCESSORY DRIVE BELT KIT COMES WITH PULLEYS #: 11287628652KT DUAL COLD AIR INTAKE BMW FUEL INJECTORS (SET OF 6 FOR N54-INDEX12) - GENUINE BMW #: 13538648937KT LIFE TIME WARRANTY NGK 93026 DILKAR8A8 LASER IRIDIUM PLUGS 6 OF THEM #: NGK93026 GAPPED AT .022 HP AUTOSPORT MODIFIED CLUTCH DELAY VALVE ULTIMATE SHORT SHIFTIER EVO3 WHOLE SHIFTIER KIT #: USSE335+86-3 VRSF CHARGEPIPE UPGRADE KIT VRSF RACE 7.5inch INTERCOOLER 1000whp RATED BLOW OFF VALVE TURBOSMART KOMPACT PLUMB BLACK DIVERTER VALVE THROTTLE BODY CLIP WITH REPLACEMENT O-RING VRSF 3" CAST STAINLESS STEEL ******* ********* V2 N54 CERAKOTE HIGH TEMP COATING/l also have a COBB set with cats for sale for anyone that needs cats CHF 11S HYDRAULIC SYSTEM FLUID (4 LITERS) - PENTOSIN #: 1405116 BMW ENGINE OIL FILTER HOUSING GASKET KIT #: 11428637821KT1 TUNER MOTORSPORT SOLID ALUMINUM ENGINE AND TRANSMISSION MOUNT SET T#: 397211 MAGNETIC OIL DRAIN PLUG (12x1.5) ES#: 251839 ECS MAGNETIC DIFFERENTIAL OIL DRAIN PLUG ES#: 3046103 HEX BOLTS WITH WASHER (M12X1.5X100) DIFFERENTIAL BOLT ES#: 56753 TORX BOLTS (M12X50) M3 HALF SHAFT BOLTS (12 OF THEM) ES#: 56910 COLLAR SCREW DIFFERENTIAL BOLTS ES#: 1875640 COLLAR NUT FOR THE COLLAR SCREW ES#: 57643 WHEEL BEARING LOCKING RING (2 OF THEM) t#: 21515 FLEX DISC BOLTS (6 OF THEM) t#: 12125 GENUINE BMW LOCKING NUT FOR FLEX DISC GENUINE BMW REINFORCEMENTS (6 OF THEM) T#: 59809 AXLE NUTS (2 OF THEM) T#: 12580 REAR WHEEL BEARING (2 OF THEM) T#: 386078 BRAND NEW BMW 335i HUBS IRP PERFORMANCE ALUMINUM &POLYURETHANE FLEX DISC WITH WASHERS T#: 401427 REAR DIFFERENTIAL MOUNTS - SOLID DELRIN RACE T#: 1453 DRIVESHAFT CENTER SUPPORT ES#: 3494058 IRP RACE SHIFTER CHASSIS MOUNT TWO BOOST SOLENIODS PRECISION RACEWORKS IGNITION COIL KIT ALL NEW BLUE VACUUM LINES |
08-13-2019, 12:01 AM | #2 |
165
Rep 428
Drives: 2008 BMW 335i Coupe
How much for downpipes and or ignition coil kit?
