Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Engine Swap n46 to n52
      08-12-2019, 01:41 PM   #1
Timothydevisser
Crazy retrofitter
Timothydevisser's Avatar
Netherlands
31
Drives: BMW e91 330i
Hey,
I have decided to build another engine in my e91.
My n46b20b is going to make way for an n52b30a.
Now I have a few questions.
I know that I need new air conditioning pipes, new power steering pipes & new coolant hoses.
The engine I can arrive without problems with attachments.
The gearbox is also no problem.
The only thing I doubt and need your help with is the following,
I have to have a dme & cas module inc keys.
should these come from a 3 series or can I also use this from a z4 or a 5 series and then flash it with winkfp and the vo / fa of my e91?
I know it is cheaper to buy a 330i but this is a hobby ( its fun ) and so I am sure I will implement it.
And i have already completely converted my e91 to an LCI inc cic and combox
Greetz Timothy
      08-14-2019, 01:05 PM   #2
Timothydevisser
Crazy retrofitter
Netherlands
31
Lol no one knows ?
      08-14-2019, 01:08 PM   #3
tlow98
2188
Drives: 2009 E91, 2014 F15 x35i
Call one of the well known tuners like bimmer geeks.
No US cars were made with the n46.
      08-14-2019, 01:43 PM   #4
hassmaschine
Drives: "NBO" 330i
You will want it from an E9x. IIRC the Z4 doesn't have a CAS and I don't think the E60 has exactly the same module either.
      08-14-2019, 01:45 PM   #5
Timothydevisser
Crazy retrofitter
Netherlands
31
IT have nothing to do with the n46...
I need to know if i can use dme and cas from other cars like a 1/3/5 or z4 and flash iT for my e91
      08-14-2019, 01:48 PM   #6
Timothydevisser
Crazy retrofitter
Netherlands
31
Looks like a cas module
      08-14-2019, 02:01 PM   #7
Timothydevisser
Crazy retrofitter
Netherlands
31
Cas model nr : 61359395657
DME model nr :12147577970
both of them are the same on the e60/e90/e89
because the dme and cas are vin locked i need both of them from the same car.
the question is can i flash them with winkfp and code them to the vo/fa from my e91 using the vo/fa of my frm to copy
      08-14-2019, 04:25 PM   #8
tlow98
2188
Ok, sorry for interrupting.
Still, call bummer geeks if you can afford the long distance, mate.
      08-15-2019, 03:14 AM   #9
Timothydevisser
Crazy retrofitter
Netherlands
31
sure you ment bimmergeeks, did send them a message thanks
      02-04-2021, 10:28 AM   #10
e90_pty
Alcides Ruiloba
Panama
Drives: bmw e90 320i
2008 320i  [0.00]
Greetings, I am new to this forum, I want to know which engine is compatible to make the change from one n46 to another, be it n52, n53 or n54 that is profitable and does not require so much adjustment or problems. or the m50, m52 or m54 family
E90 320i N46 automatic
@alqaeda_507 instagram
@[alqaeda_507](contact:560632)
      02-04-2021, 12:09 PM   #11
Bmw1939
268
Drives: BMW 2011 328i, 2008 BMW X3
What is up with your username? Al Qaeda?????
      02-04-2021, 12:16 PM   #12
lookalikehuuh
Drives: 2006 330i, 2007 335i
I've always wondered whether its just easier/cheaper just to buy a similar car with an N52 engine in it. I mean E90s are fairly cheap nowadays even with the COVID used car premium we are seeing lately.
      02-04-2021, 03:30 PM   #13
ADEe92
Australia
253
Drives: e92 320d sport plus edition
2013 320d  [0.00]
1988 320i with M30B35  [0.00]
It would definitely be cheaper to just buy one, but the OP pointed this out earlier on.
I'd say the N52 isn't enough of an upgrade for the effort - throw a V8 in there - but given the OP is in the Netherlands, the car mods allowed are very tight so a V8 probably isn't an option.
      02-04-2021, 10:10 PM   #14
E92William
1998
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
A nice n52 or n53 from a 330 would be a ridiculously good upgrade over the 4 cylinder toaster n46 both in power and reliability. I'd say buy a crashed car with the engine you want and swap that stuff over to yours and if your country doesn't like engine swaps you swap the fucken vin number too lol
      02-05-2021, 11:26 AM   #15
Asreegan
Asreegan's Avatar
Malaysia
Drives: E92
E92
Hi all,
I've just recently converted my e92 from n46 to n54..I only managed to get hold of a e91 which everything was transferred to my e92..The issue is that e92 originally drops and raises its windows 5/6mm when the doors are opened and closed, since my wiring is from an e91 that feature doesn't operate..appear it's your guidance If I could get it to work..aside to that my central locking doesn't work as well..would it be possible to make it operate again..your guidances are very much appreciated
