Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Any way to keep my engine temps down?
      08-11-2019, 09:33 AM   #1
thormessiah
thormessiah's Avatar
165
Drives: 2008 BMW 335i Coupe
2008 BMW 335i  [0.00]
I live in Texas where it’s usually 95+ degrees even around 11 pm at night. My hood is usually hot enough to fry a couple eggs on it after just 5 minutes of light driving. Is there any other way to keep engine bay cool? I have a ARM 5 in inter cooler, 1 year brand new radiator, but I do have BMS DCI and removed the stock box and filter. Thanks
      08-11-2019, 09:54 AM   #2
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
If it's not overheating and not exceeding 250F, your engine is running at the temperature it's designed to run.
      08-11-2019, 12:16 PM   #3
Fritzer
No one sleep in Tokyo
Fritzer's Avatar
945
Drives: 2011 E90 328i//1995 E34 530i
Heat wrap, aftermarket oil cooler, bigger intercooler. Check out certain ducting mods to get better airflow like the aFe air scoops behind the kidneys, or something along the line of how Dinan made their ram-air intake by ducting extra air from the front left bumper grill, near the foglight.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
      08-11-2019, 07:11 PM   #4
rawdog573
Drives: bmw 335xi
If you have mhd tuner you can target cooler coolant temps. On track mode I've seen around 200 degrees just normal driving. But I don't leave it there. I normally leave mine on sport so it targets around 220 or so normal driving
      08-11-2019, 09:36 PM   #5
Bimmer_Engineer
Bimmer_Engineer's Avatar
1044
Drives: 2007 335i
Are you wanting to keep it cool just for the sake of keeping the car cooler? I ask because if you’re looking to get your intake air temps down you might consider putting the stock air box back on...
tisdrew97.50
      08-11-2019, 10:23 PM   #6
Bobocut95
Bobocut95's Avatar
Drives: BMW 328XI
I would just watch your engine temps. If that is good then you should be fine.
      08-11-2019, 11:11 PM   #7
porsche959
471
Drives: porsche
Probably going to get flamed on but removing the plastic undertray significantly reduces engine temp. At least I think I read that somewhere.
      08-12-2019, 08:19 AM   #8
tisdrew
98
Drives: 2009 335i
BMS has a cheap oil cooler thermostat in addition to the things everyone has mentioned. I would look into water-meth injection if you're open to that.
"Wheels and exhaust aren't a build"
      08-12-2019, 10:58 AM   #9
thormessiah
165
Thanks all! I will probably save up for the CSF radiator which is a big upgrade over the stock one
      08-12-2019, 12:42 PM   #10
nsjames
2440
Drives: 08 328xi Touring
you can have the worlds most gigantic radiator ever, but the thermostat is still going to keep the engine at 200+ degrees.
the factory setup is perfectly capable of overcooling the engine.
the thermostat is what keeps the heat in the engine.
also, a better radiator isn't going to decrease underhood temps.
all that heat is still going to flow from the back of the radiator into the engine bay.
if you want cooler engine bay temps you need to vent the engine bay.
      08-12-2019, 01:18 PM   #11
mecheng77
mecheng77's Avatar
1006
Drives: 2007 328i / 2014 M235i
  [0.00]
  [0.00]
^This is correct.
Maximum efficiency is gained at higher temps. I would make sure your oil is full and you can remove the vanity cover. When the car is stone cold, use a garden hose to spray the radiator and evap fins.
From what I remember, driving in DS mode keeps the water temperature lower by running the electric water pump faster but you will lose efficiency. These cars have very intelligent cooling systems.
      08-12-2019, 05:30 PM   #12
1sicke92
1sicke92's Avatar
69
Drives: 09 E92 N54
low temp thermostat, radiator, oil cooler, larger IC?
FBO + PURE STAGE 2 + MHD FLASH
      08-12-2019, 08:37 PM   #13
thormessiah
165
Would a vented hood be a better investment?
      08-12-2019, 08:57 PM   #14
Ozzie335i
Drives: 2011 335i
Ding ding. I have the AD Engineering one, thought to be the happy medium between summer cooling and winter heating. Friday night going out for dinner it was 107 degrees out. While cruising at 85 mph the temp gauge on my ride was comfortably pegged at 210.
      08-13-2019, 12:34 PM   #15
Anthony199
15
Drives: BMW 325i 06 Sparkling Graphite
That might be the stupidest proposition you will hear but maybe putting a higher viscosity oil (5w40 instead of 5w30 if that's what you're using) will help with oil temperature. I'm not sure how accurate and effective this is so roasting is welcomed
      08-13-2019, 02:45 PM   #16
thormessiah
165
Actually I also heard this from 2 guys who worked on my n54 about a year ago. They were using Rotella 5w40 because they said it ran a little cooler. I had my oil changed at a local store so they used 5w30 but I'll be using 40 from now on.
      08-13-2019, 03:37 PM   #17
nhhiep
88
Drives: bmw
Would using 5w40 damage the engine in anyway? Instead of stock 5w30? I live Denver, so temperature can be from 0 to 100 f
      08-13-2019, 03:52 PM   #18
Anthony199
15
No, definitely no harm. In the contrary actually, 5w40 is more viscous, so it would provide better lubricantjon in hotter climates. However, I am not sure about this statement either, but in freezing temps, it doesn't provide the best lubrication in tight areas on and during cold start/idle. BMW does recommend both oils in the manual, so just make sure it's a BMW long life 01 approved oil. Castrol edge, pentosin or liquy moly are all good. I get my liquy moly from FCP euro as a kit with the filter, and with the lifetime warranty, I buy a new kit, send the old kit with the old oil for 18$ back, and get the new kit price refunded to me, so it's 18$ oil changes haha
      08-13-2019, 04:46 PM   #19
zomski101
Drives: 2009 BMW 335i
I got the seibon gtr hood and its no different. Only see the heat wave escaping. Maybe run e85.
      08-14-2019, 11:48 AM   #20
nsjames
2440
if your goal is a cooler engine bay, yes.
I'm still not sure what your goal is here.
you talk about engine temps but then you talk about your hood being hot.
Your engine is designed to run hot, that's just how it is these days. IIRC the upper map for the thermostat is like 215.
twenty years ago that would have been the red mark on the gauge.
if your car doesn't overheat, it's fine and working just as designed.
