Advice for glue removal needed...
08-10-2019, 04:02 PM | #1 |
15
Rep 184
I recently had to reglue my rear view mirror mount with some auto parts store mirror glue. I managed to get it in the wrong orientation and now I don't know how to get the damn thing off to glue it in the right orientation. If anyone has suggestions please let me know. So far I have tried heat and pliers but have been unsuccessful.
Thanks! |
08-10-2019, 08:31 PM | #2 |
242
Rep 1,354
Get a thin pain scraper about 1" wide.
Sharpen the tip on a grinder as sharp as possible. Wedge it under the mount and lightly tap it sideways with a small rubber mallet until the glue releases. Never exert force perpendicular to the windshield surface and use light taps to work the scraper in further and further. |
08-11-2019, 08:22 AM | #3 |
17315
Rep 18,737
I think opjose advice is spot on. I'd like to suggest adding a little chemistry to the process. I think you should try applying a small amount of Acetone to the adhesive and letting soak. Do this by wetting a Q-tip swab and squeezing the Acetone into the edges of the mirror button. Please if you use Acetone, cover the dashboard with a heavy cotton towel folded over a few times incase the Acetone drips off the Q-tip.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
08-11-2019, 08:38 AM | #4 |
1209
Rep 2,476
I would exhaust chemical attempts long before I'd try mechanical efforts. Seen plenty of cracked windshields when people tried prying those things off.
