BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > 2009 E92 335xi Transmission rumble/hesitation
      08-09-2019, 07:55 AM   #1
bluelair
Drives: 2011 M3 E93
2009 335xi automatic with 76k miles. BMS tune, charge pipe and intake mods installed. Transmission is original, with original fluid.
Transmission is giving a slight hesitation/rumble when just starting out in 1st gear. Shifts fine otherwise. Took it to local imports shop and mechanic says he doesn't know exactly what is wrong, but that car will likely need new transmission soon. He says the fluid looks brown, and that is an indication that things are failing inside.
He doesn't recommend doing a service, changing fluid, filters, etc, just that we start thinking about selling the car as it will require a new tranny in the next 10,000 miles.
What do you all think?
      08-09-2019, 09:28 AM   #2
pwner4once
Drives: BMW 328i Coupe / 07
what is his reasoning behind brown color = transmission going out soon?
unless there are metal pieces, i don't get why the discoloration hints at a mechanical failure.
      08-09-2019, 09:37 AM   #3
bluelair
Drives: 2011 M3 E93
I asked him that exactly, he said just based on the color, he said he's seen this before in this model. He said it was brown, indicating and I'm quoting "things are starting to come apart in there."
What would you recommend?
