08-08-2019, 02:37 PM | #1 |
Supreme Allied Commander
3815
Rep 54,307
Drives: F80 M3
Brembo Premium Ceramic Pads
This is our most popular pad for street duty, low dust, and OE like performance. If you like to keep your wheels clean after a wash and not give up brake performance(most of the dustless pads don't perform as well as OE), this is the pad for you!.
Specifically designed for the North American market, this Brembo formulated friction material with premium shim offers comfortable, quiet, smooth braking and cleaner wheels. Designed and engineered to enhance braking power, Brembo Ceramic Brake Pads minimize braking distances while offering a quiet and safe braking experience on a variety of road conditions. Original Equipment Direct Moulding Pressing Process provides a proper and accurate fit. The positive molding process uses extreme pressure to compress friction materials and provide balanced bonding to the backing plate. Each pad is then thermal scorched following Brembo's O.E. specifications to lessen running-in and fading. Brembo's multi-layer ESE (Elastomer - Steel - Elastomer) red shim, clearly identifying the pads as Brembo pads, dampens noise and minimizes vibrations. Additional noise dampening is handled by the backing plate which also acts as a heat shield to reduce heat transfer to the caliper. Developed for a wide range of applications, including premium imports and domestic models, Brembo Ceramic Brake Pads offer the performance, dust reductions, comfort, reliability and longevity drivers demand. Vehicle Fitment: F2X F3x F8X with BMW Sport Blue Calipers. Order here: https://hpautosport.com/product/brem...port-calipers/ Last edited by HP Autosport; 07-13-2023 at 07:27 PM.. |
11-10-2019, 06:51 PM | #7 |
3815
Rep 54,307
Drives: F80 M3
This is one of the best street pads that are low dust and very quiet.
07-18-2020, 06:39 PM | #20 |
3815
Rep 54,307
Drives: F80 M3
this is one of the best aftermarket OE replacement pads out there. OE performance without the dust!
