Bimmerpost
4 Series
Technical Topics Wheels and Tires 20" wheels too agressive?
      08-08-2019, 09:59 AM   #1
sspdw
71
Drives: bmw m140
Looking at a set of flowformed 20" wheels in the following specs.
The rear rims will be poking out an extra 19mm. Will it be too much?
Front 20*8.5 ET 35 with 235/35/20
Rear 20*10 ET 40 with 265/30/20
      08-09-2019, 09:01 AM   #2
BMW435
BMW435's Avatar
Switzerland
345
Drives: BMW 435
I will put the same size ! Please post some pictures when done !
      08-10-2019, 04:08 AM   #3
Brett240
Brett240's Avatar
39
Drives: G20 330i
19 is pushing it. i have 13mm spacers on the stock rims and wouldn't want them to stick out any further.
pneumodoc233.00
      08-20-2019, 03:45 PM   #4
pkancel
pkancel's Avatar
Drives: BMWs
I put 10mm spacers on the rear and could have gone a little more but no way 19, way too much, will stick out past the fenders and look silly plus if your car is M-Sport or you plan to lower may rub.
      08-23-2019, 10:20 AM   #5
sspdw
71
Drives: bmw m140
Yeah thats what im thinking, But a 265 would only stick out a extra 5mm on a Et40. On the standard m791, my tires are a good 15mm outside the lip of the rear rims, this will not be the case on a 10" with 265.
      08-26-2019, 06:35 PM   #6
Wmzorba09
326
Drives: Bmw M340 2020
Aggressive idk but impractical for a daily driver absolutely
      08-26-2019, 07:23 PM   #7
raptorapture
raptorapture's Avatar
Drives: 2020 m340i
2020 M340i  [0.00]
Just for reference regarding front strut clearances (they are tight), this is 19x8.5 ET 25 with 245/40/19
So comparing your desired measurements you would be sitting about 20mm ~ horizontal outwards from where my setup is but with the added wheel diameter, it will be even tighter if not hitting the base of the strut.
The bottom plate of the strut overhangs the tire about an inch with about a half inch clearance between the tire and the strut
Could clear with a spacer I guess, but then your fronts will likely poke out of the fenders.
Front Fender profile.
      08-28-2019, 02:41 AM   #8
sspdw
71
Drives: bmw m140
Yeah i see, but a 235/35/20 is 5mm less diameter than 245/40/19. I guess it will be similar to your picture.
g20
