Replace front brakes now have a Christmas tree
08-06-2019, 06:00 PM | #1 |
37
Rep 233
So like the title says. I replaced my front brakes today. Changes the pad sensor also. I was careful with everything. Check brake fluid resivor to make sure it was proper level when done. Pumped brakes up before starting. Finally start car to go drive and get the pads broke in. Didn't even move a foot and traction control light came on. 4x4 malfunction and brake light. Just curious as to what would cause then. I then got bsck under neath to make sure I didn't maybe break the abs sensor and to make sure pad wear sensor was plugged in correctly. Everything was good. Got bsck in drove 10ft and the lights went off. Confused to as to why this happened. Couldn't check codes cause mhd won't tell you anything other than engine codes it seems like.
08-06-2019, 06:01 PM | #2 | |
37
Rep 233
08-06-2019, 06:11 PM | #3 | |
Rep 8
08-06-2019, 06:57 PM | #4 |
866
Rep 5,451
It is pretty normal you get that trifecta of lights and as soon as you drive a few feet they will automatically clear as it recalibrates. You will get them if you disconnect the battery and for many other reasons if something is disconnected or if the ABS sees something a bit funny, so probably just that first press once started was low in pressure and set them off. As long as they clear after you drive a very short distance nothing to worry about. If they come on regularly or stay on then there are a few things that can cause it, transfer case clutch actuator, bad wheel sensor, abs module failing, but yours sounds normal.
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
08-06-2019, 07:00 PM | #5 | |
37
Rep 233
