Adaptive Headlight Vertical Axis Reversed
08-05-2019, 08:03 AM | #1 |
Rep 9
Pass side headlight got some water in it an fried the adaptive module. Replaced the module, error went away and adaptive function works fine with one exception... the vertical axis is reversed. When the headlights start up the pass side headlight moves vertically in the opposite direction, and as a result at the end of the test moves downward (vs the drivers side moving upwards) to its final position. Is this something I can reverse in the coding?
Any help greatly appreciated, searching hasnt lead me anywhere thus far. |
08-05-2019, 02:49 PM | #2 |
464
Rep 2,773
module should be recoded after replacement
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
