Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > What size tires do I buy for these rims?? (2011 BMW 328XI)
      08-04-2019, 05:11 PM   #1
JackDesmarais
Drives: 2011 BMW 328XI
Hey everyone, I just have a quick question. Does anyone know what size tires I would want to buy for these rims? I bought staggered 19 inch rims (front 8.5x19) (back 9.5x19) . I drive a 2011 bmw 328xi
JacksonDesmarais
      08-05-2019, 04:59 PM   #2
dakine_surf
dakine_surf's Avatar
433
Drives: TiAg e91, r53 Cooper S, e28 M5
What is the offset front and back for those wheels?... that will help determine the size of tire you are looking for.
Also is the suspension stock?
      08-05-2019, 05:08 PM   #3
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Read this.
https://support.apexraceparts.com/hc...bile_site=true
You have to really careful with tire sizes on an XDrive.
      08-05-2019, 05:20 PM   #4
jwalker87
jwalker87's Avatar
Drives: '08 335i, '11 335xi, '01 Z3M
Essentially, what you want to do is find a tire size calculator online (google it, there are dozens at least). Put in the stock tire sizes and see what tire sizes might work with your new wheels to end up around the same overall diameter, sometimes represented in % speedometer error. Play around with the widths and sidewall ratios as well as look at what sizes your favorite tires are offered in. Those tires should list acceptable wheel widths for that application.
I have 9.5x19" rear wheels on my 2008 335i, and 275/30-19 works well for me. For the front, you're probably looking at something like a 255/30-19 or 245/30-19.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd
2011 e90 335xi 6spd
2011 e70 x5 diesel
2010 Ducati Monster 696
      08-05-2019, 05:32 PM   #5
RealJ22
RealJ22's Avatar
1039
Drives: E92 CT200h Cayman Boxster RC
2007 BMW 335i  [0.00]
That wide for the front? My coupe can barely do a 235/35/19.
Like he said, you need a calculator to make sure the rolling diameters are within 1%
I believe a 235/35/19 and 275/30/19 are the exact same height and rolling diameter.
      08-05-2019, 05:46 PM   #6
jwalker87
jwalker87's Avatar
235/35-19 is probably the way to go then. I have 9" front wheels so it's a little different from the OP. At least for the Michelin Pilot Super Sports, they list an acceptable rim width of 8-9.5" for the 235/35-19 as well as the 245/35-19, so that seems well-suited.
2008 e90 335i 6spd
2011 e90 335xi 6spd
2011 e70 x5 diesel
Appreciate 2
RealJ221039.00
      08-05-2019, 10:52 PM   #7
Serf27
Serf27's Avatar
2851
Drives: 335i
“xDrive must use 235/40-18 front and 265/35-18 rear tires.
xDrive LCI sedan and wagon must use 225/40-18 front and 255/35-18 rear “
I am running lci xdrive setup on a pre lci xdrive
(225/40/18-255/35/18)
Am I going to run into trouble?
