Bleeding brakes question
08-04-2019, 01:39 PM | #2 |
83
Rep 687
I think its recommended you use BMW software to bleed the brakes whilst activating the ABS pump. However I recently changed my calipers to the F series blue Brembo's and did a gravity bleed and the brakes have been fine.
08-04-2019, 05:17 PM | #4 |
17315
Rep 18,737
Use a pressure bleeder or an assistant. No need to use a computer to activate the ABS module.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
Pladi718.00 |
08-04-2019, 07:02 PM | #5 |
1044
Rep 1,667
I used a pressure bleeder for the first time a few months ago...what a sucker I was to pump the brake pedal for all those years...
Persian Whisperjet166.50 |
08-04-2019, 10:45 PM | #6 |
80
Rep 354
I just replaced the ABS pump and flushed all my lines. I used a pressure bleeder first. Pedal was a bit soft, so I did it again with the foxwell tool activating the pump. Pedal felt great after.
08-05-2019, 07:16 AM | #9 |
2657
Rep 6,290
08-05-2019, 08:46 AM | #10 | |
398
Rep 1,579
https://www.bimmerfest.com/forums/sh....php?t=1023698 |
08-05-2019, 09:09 AM | #11 |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
According to the Bentley Repair Manuel:
- Have partner in the cabin - you open the bleed screw and say "open" - after you say open, your partner pumps the brakes (10x) - on the 10th pump, he/she puts the brake pedal to the floor and says "hold" - after you hear "hold", you close the bleed screw. Start with Passenger Rear, Drivers Rear, Passenger front & finally Drivers front. The brake fluid reservoir should be closed during this procedure. You should add brake fluid after every time you do this. You will need a brake bleed bottle. Attach it to the nipple and then turn the screw. Do not, detach the nipple while the bleed screw is open. I would say (3x) per brake to be safe. INPA & ISTA D I "think" only have software for the ABS bleeding. |
08-05-2019, 09:12 AM | #12 |
1903
Rep 6,968
I'm not a huge fan of brake vac's or pressure bleeders for "bleeding" the brakes. They do a great job of flushing the brake fluid and that's about it. I have a Miti-Vac. I've had it for 8 years or more. LOVE IT, but it's not good for bleeding brakes.
See my other post. Best bet with bleeding brakes is old school. If you need to bleed the ABS, then use software. |
08-05-2019, 09:20 AM | #13 | |
17315
Rep 18,737
08-05-2019, 10:05 AM | #14 | ||
1903
Rep 6,968
08-05-2019, 11:03 AM | #15 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
FYI Schwaben scan tool can activate the ABS pump
Did my 4th, 5th and 6th bleeds yesterday with it
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
08-05-2019, 11:09 AM | #16 | ||
2440
Rep 4,330
I've done it all ways. pressure bleeder is effective, even at bleeding a completely dry system. you're doing it wrong if it doesn't work properly. frankly it's about the only way to properly bleed a clutch. and yes, I own a mity vac, a compressor powered vacuum tool, and I've done it old school and with speed bleeders. pressure bleeder > than any other method |
Bimmer_Engineer1043.50 |
08-05-2019, 01:11 PM | #17 |
17315
Rep 18,737
I've been bleeding brake systems for an easy 35+ years. Never used anything but a buddy or my wife as old school method. Four years ago I switched to a pressure bleeder. Easier to bleed with a pressure bleeder and have never looked back. Both processes flush the system, hence it's called a "brake flush". What, in your opinion, does pumping the system do differently/ better to flush it vs. pressurizing it to flush it? I'm just curious.
08-05-2019, 01:15 PM | #18 | |
17315
Rep 18,737
08-05-2019, 01:17 PM | #19 |
Robot
1685
Rep 2,191
What's the difference between flushing and bleeding?
08-05-2019, 10:35 PM | #20 |
382
Rep 891
is this that brake pressure bleeder somebody was talking about?
https://www.amazon.com/Motive-Produc...%2C218&sr=8-11
09 328i TiAg 6MT barebones with sport package
08-05-2019, 10:52 PM | #21 |
1209
Rep 2,476
Didn't realize the intent was to pump air INTO the system...
08-05-2019, 11:01 PM | #22 | |
1903
Rep 6,968
I've bleed brakes this way more then just a few times this way and on more than just BMW's. It works. |
