Bimmerpost
4 Series
2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Tyre Pressures
      08-04-2019, 12:29 AM   #1
Pentop63
Pentop63's Avatar
United Kingdom
14
Drives: X4 M40i
Tyre Pressures
Just had the car parked up for a couple of weeks and had a tyre pressure warning in the front tyres. This was via the car message centre but the mobile app still shows an okay status ?
Anyway, the panel in the car which has the following pressures listed and wanted to understand what people are using.
Front tryes are - 225/40R 19 93Y - 33 PSI or 41 PSI for ECO ??
      08-04-2019, 08:01 AM   #2
Carjack
Stormtrooper
Carjack's Avatar
United Kingdom
169
Drives: 330i G20 M-Sport Portimao Blue
According to the panel in my car, for 19R :3 people - 225/40 R 19 Y 93: for front 39 psi rear 39 psi
For ECO; front 46 psi rear 46 psi.
Think you have been reading off the table for 225/50 R17 98 Y.
I stand to be corrected of course!
      08-04-2019, 10:06 AM   #3
Pentop63
Pentop63's Avatar
United Kingdom
14
Drives: X4 M40i
Just checked the car message centre and it recommends 2.5 bar on all four tyres which is 36 PSI.
Different what the panel says... I am now officially confused
      08-04-2019, 10:20 AM   #4
Pentop63
Pentop63's Avatar
United Kingdom
14
Drives: X4 M40i
I’ve enclosed my panel just in case I’m reading in incorrectly
      08-04-2019, 01:41 PM   #5
Carjack
Stormtrooper
Carjack's Avatar
United Kingdom
169
The labels are different! The type pressures are different!
Perhaps they are different due to the model of the car, mine is an M-Sport with adaptive suspension.
      08-04-2019, 01:50 PM   #6
Pentop63
Pentop63's Avatar
United Kingdom
14
Drives: X4 M40i
Wow... mines a M-sport, how do I know if I have adaptive suspension ? As it was pre built by the dealership
      08-04-2019, 02:54 PM   #7
Carjack
Stormtrooper
Carjack's Avatar
United Kingdom
169
Should be on your Dealers receipt or Bill of Sale.
Failingly that there are various web sites that if you type in the cars VIN number all should be revealed.
Even so the tyre pressures are quite different and unless you haven’t got sport suspension and I do not think that can be specced out for the G20 unlike the old days.
Bit of of a mystery!
      09-01-2019, 03:13 AM   #8
Gregus330i
Gregus330i's Avatar
United Kingdom
102
Drives: BMW 330i M Sport
There's a button on the centre console which says 'adaptive' :-)
      09-01-2019, 03:25 AM   #9
KMoore
KMoore's Avatar
United Kingdom
19
Drives: G20 320i M Sport
Go with the plate on your door pillar, not the software.
      09-01-2019, 05:48 AM   #10
oldmick
oldmick's Avatar
England
36
Drives: BMW G20 330i Msport
That’s got nothing to do with suspension, it’s for adaptive drive.
BMW g20 330i msport
Portimao blue, Technology pack, Comfort pack, Msport+ pack, Premium pack, Visibility pack
      09-01-2019, 06:08 AM   #11
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
United Kingdom
443
Drives: BMW G20 330i RWD M Sport
BMW configuration builder says M Sport + package gives you “Adaptive M Sport suspension”
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      09-01-2019, 11:53 AM   #12
HighlandPete
6659
Drives: BMW F11 535i Touring
The Adaptive mode button is part of the control (one option) for the adaptive suspension.
      04-16-2023, 01:10 AM   #13
G30M
G30M's Avatar
3707
Drives: BMW M550i; Kia EV6 GT
Pentop63
Sorry to trouble you 5 years later - was your car using runflats or non run flats if you recall? also, a G20 car?
I'm switching from run flats to non run flats and would like to know the correct pressures for non run flats as i am guessing yours were ... thanks for your help
      04-16-2023, 01:11 AM   #14
G30M
G30M's Avatar
3707
with these high pressures i presume your car can with run flat tyres?
sorry it's a few years down the line but i am switching from run flats to non run flats and i am trying to figure out this discrepancy. thanks
Carjack
      04-16-2023, 09:39 AM   #15
HighlandPete
6659
Should be on similar pressures, if tire sizes and ratings are the same as the run-flats.
Some users find a couple of extra psi give a better feel. Best to start where you are now (with RFTs) and experiment.
drs4m1.50
      04-16-2023, 10:08 AM   #16
NLJ
217
Drives: 2023 M340i
Hopefully the BMW recommended tire pressure will not wear out the middle of the tire quickly.
My Genesis G70 was maintained by the dealership its entire ownership with exact recommended pressure on nitrogen and yet my middle went bald on the Michelin PS4 for the rear tires.
Granted the M340 is is a different car and PS4s but it is recommending a higher pressure than my G70 did with the same size staggered setup.
My tire shop recommended going down by 1-2 psi especially during summer cause we can have up to 36C days here in Ontario.
Search this Thread:
Advanced Search
g20
