Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > N54 Aftermarket oil cooler adapter leak
      08-03-2019, 09:39 PM   #1
Zedxadam
Drives: 2007 335i Coupe
I can not keep aftermarket oil coolers from leaking at the adapter block. I have tried a few different blocks and o-rings.
Does anyone have any suggestions?
I am also debating removing the stock oil cooler and running the aftermarket cooler lines into the thermostat to help eliminate leaks. Does anyone have any experience with the turner adapter? Leaks, no leaks?
Any other ideas as to how to plumb the aftermarket oil lines into the thermostat?
Thanks
      08-03-2019, 11:07 PM   #2
Red_Bean_Bun
62
Drives: E92
Which make is your oil cooler ?
The ones from Sebtrab seems to be ok. Those made in china - always seems to leak.
      08-07-2019, 09:02 AM   #3
Zedxadam
The cheap ftp one, but it is not leaking anywhere other than at the adapter block at the o-rings. I have tried two other adapter blocks and different o-rings, with no success.
