Limp Mode at 5k: Help diagnosing
08-02-2019, 01:51 PM | #1 |
12
Rep 117
I’m getting limp mode at or around 5K rpms or WOT on my 07 335i and I’m not exactly sure what’s causing it. I’m pulling codes 30FF and 29F3 Fuel pressure sensor. Am I getting limp mode because of one of these sensors? If so which one should I replace low pressure or high? It could also be a vacuum leak but I don’t see how that would cause limp mode right at 5k but I’m not sure. Any recommendations/insight would be greatly appreciated.
-Josh |
08-02-2019, 09:30 PM | #2 | |
37
Rep 233
Now with no issues boosting 18psi |
08-03-2019, 09:26 AM | #3 |
12
Rep 117
How did you do that? How much are boost solenoids and is it a doable fix?
08-03-2019, 09:52 AM | #4 | |
37
Rep 233
08-03-2019, 02:25 PM | #5 |
654
Rep 1,893
Excuse me but why the fuck is anyone talking about boost solenoids?
30FF is low boost which happens because the DME shut off the turbos because there is a fuel pressure problem. 29F3 indicates (I believe but look it up yourself) a problem with the low pressure fuel sensor. There is likely either a) problem with the sensor, b) problem with its wiring, c) problem with the fuel pump. Log a few runs and see what the fuel pressure is doing. |
08-03-2019, 09:08 PM | #6 | |
12
Rep 117
08-04-2019, 05:20 AM | #7 |
654
Rep 1,893
If you are going to work on the vehicle yourself, you need to make some modest investments in diagnostic tools. You were able to read codes but I don't know how that was done, conceivably you just went to autozone and had them do it. If you don't have a decent scanner, one that can read BMW specific codes and report freeze frame information, either get one or install the freely available BMW factor software (BMW Standard Tools - needs DCAN cable - get both at bimmergeeks.com). For logging, I like MHD, which many people use to flash parameter maps to the DME but can also log and also report error codes and is simple to use.
Judging by your first post, I'm guessing you haven't got much experience with the N54 engine. You've got two ways to go: do some reading to educate yourself and apply some critical thinking in your diagnosis to make sense of the codes and other information your diagnostic tools provide. Or just randomly replace parts - that gets really expensive really fast and is generally quite frustrating. |
08-04-2019, 07:33 PM | #8 | |
12
Rep 117
08-05-2019, 05:42 AM | #9 | |
654
Rep 1,893
Your DME is giving you the clearest possible indication that you have a fuel problem. You could read the fuel pressures with INPA: E90->engine->N54->live data->analog measurement blocks-> OBDII. You can only read the rail pressure directly but if you either activate the pump with INPA or just turn ignition but not engine on. Then the rail pressure is reflecting the pressure generated by the LPFP - should be steady and well above 50psi, ideally 65-72. You can also start the engine and verify rail pressure higher than 600 psi, reflecting HPFP operation. In german rail pressure = Kraftstoffdruck or raildruck and values may be in kPa, not psi. Or you can spend $100 on MHD and get a graph of high and low pressure values over time while operating the car in real world conditions. If you are going to randomly replace stuff, the low pressure fuel sensor is the obvious choice. Best of luck Last edited by dpaul; 08-05-2019 at 10:53 AM.. |
Tags |
29f3, 30ff, 5k rpms, diagnosing, fuel pressure sensor, limp mode, limp mode at 5k |
