[SOLVED] Drain plug question on new Behr radiator
08-01-2019, 07:24 PM | #1 |
15
Rep 154
Hello everyone!
Just replaced my radiator on my 325i 2006 with a OEM Behr one from FCP Euro. The bleeder screw on my old radiator was blue and was two screws screwed together. The new radiator has a one piece bleeder screw, and comes with an o-ring. I am not sure if I can use it or if I should order a new one? I've seen videos where kits are sold with a pair of two types of bleeding screws, but I'm not sure if it's necessary for the Behr one. No leaks on new radiator. Thanks. Solution: Read the Q&A section of the radiator listing on FCP Euro, and someone else already asked the question. Sorry for wasting your time guys, should have done more research outside the forums. Here was the reply to the same question: "The drain plug is completely different than the OE plug. It is pre-installed on the radiator out of the box. It is not a replaceable item." Last edited by Anthony199; 08-01-2019 at 08:35 PM.. |
08-01-2019, 07:48 PM | #3 |
15
Rep 154
08-01-2019, 08:44 PM | #4 | |
Is it the shoes!?
3884
Rep 5,112
Contrary to FCP Euro, it is actually a replaceable item. |
08-01-2019, 08:49 PM | #5 | |
15
Rep 154
12-21-2020, 10:46 AM | #6 | ||
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
12-21-2020, 12:08 PM | #7 |
1998
Rep 2,026
Drives: 2008 E92 328xi
I thought the consensus with these radiators was to never take the plug out unless you're going to replace the radiator because it will break and not go back in properly. I'd just remove a hose
12-21-2020, 01:15 PM | #8 |
133
Rep 323
I just replaced mine last week or so on 2006 330i radiator. I used the brass one below, some silicone and a nickel to lightly tighten it. It hasn't leaked.
https://www.amazon.com/URO-Parts-171...8578035&sr=8-4 You can look on FCP Euro to see if it will fit or find the part number there. |
12-21-2020, 01:32 PM | #9 |
108
Rep 241
I wish I could have seen this post a week ago, before I drained the cooling system and removed the drain plug from the hex part and broke it. Luckily, ECS tuning had it in stock.
Part numbers can be found in this thread: https://www.e90post.com/forums/showt...php?p=12960625 |
12-21-2020, 01:56 PM | #10 |
382
Rep 891
Just an FYI, that plug has 2 OEM versions, one is for an mt and another is for an at car. If you put a wrong one in your radiator, you’ll either have a leak or overheat your trans.
