Can 2A13 DMTL and 30FF codes be linked
08-01-2019, 06:43 PM | #1 |
17
Rep 193
Drives: 2009 Black 135i
2011 335is, Can 2A13 & 30FF codes be linked?
I haven't been able to find much of anything on these codes together but they came on at the same time. before I buy a new leak detection pump I was wondering if anyone on here has any knowledge on this.
08-01-2019, 07:19 PM | #2 |
17
Rep 193
2011 335is
08-01-2019, 08:46 PM | #3 |
90
Rep 386
Drives: 08 535xi 11 328xi
I do not believe they will be related in any way. 2 separate issues. leak detection pump only operates when you turn the car off. 30ff happens when under acceleration.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe |
08-15-2019, 01:12 PM | #4 |
17
Rep 193
hopefully answer works for anyone else in the future who has this issue. I'm glad there is finally an answer out their to my original question. I read that the leak detection pump works off of the cars vaccum lines so I had my fingers crossed that replacing the leak detection pump would be the remedy to both codes. Order my Leak Detection Pump from my favorite online store ECS tuning, replaced the pump yesterday(easy fix) info on YouTube, my 335is pump location was on the driverside. This afternoon I deleted the 2 codes before the test drive and drove for about 10-15 mins, hitting the throttle hard enough to build boost and "I have boost again!!!", so far those 2 codes have no reappeared. This leaves my to speculate that these 2 codes are in fact interrelated and replacing the pump will remedy the problem.
I will post and update if the code or codes reappear. Thank you to the only person awesome enough to respond to my post. |
08-15-2019, 02:07 PM | #5 |
17
Rep 193
My bad
lol, I dont know why 30FF didn't activate my first run....but now it did now I gotta figure out where
08-16-2019, 03:36 AM | #6 | |
202
Rep 713
i got 30FF (and only this one) sometimes when one of my wastegate got stuck open, after some WOT. 30FF just mean that the boost is under target (from a leak or something else like wastegate stuck), and then it disable the wastegate operation to protect your turbos. |
