08-01-2019, 04:24 PM | #1 |
Rep 19
KW coil-over owners?
I've been at the cash register for two months searching for the right set of coil-overs for my 2014 335i xdrive. I have narrowed it done to the KW V1. My only issue is and maybe all you with this set up can help me finalize this decision. Have any of you had issues getting a perfect wheel alignment on the vehicle due to NO camber adjustment plates on these sets?
Also any E30 M3 owners that can recommend a nice set? Non track car, strictly street show car. Thanks in advance. |
08-01-2019, 09:27 PM | #3 |
480
Rep 681
I didn't have any issues with alignment. I fairly low on them as well. More front camber in front due to going lower has a beneficial effect on turn in and handling. I wouldn't worry about it.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
08-04-2019, 11:17 AM | #6 |
480
Rep 681
The rear has camber adjustments. In front, you can add it by using camber bushings on the LCA. There's also an OEM wheel carrier which adds -0.5 degree of camber iirc.
2006 997.1 C4S |
08-04-2019, 01:37 PM | #8 |
Rep 19
08-04-2019, 01:41 PM | #9 |
Rep 19
THE reason why camber alignment is a concern for me is because my E30 M that I've owned for 28 years full front end rebuilt due to drastic towers flexing in junction with rust built up. I was eating tires like an Ethiopian.
08-04-2019, 01:43 PM | #10 |
Rep 19
08-04-2019, 04:22 PM | #11 |
Rep 75
08-05-2019, 11:38 AM | #12 |
Cheapskate
4450
Rep 4,993
Your front camber won't be any more out of wack than it is in the stock suspension. One side will always have more camber than the other until you get camber plates. I added Millway plates to mine.
https://f30.bimmerpost.com/forums/sh....php?t=1605949 Also, check your knuckles before ordering the offset ones. Yours might already have the +.5 or -.5 bearings from the factory. |
