Burning money e90 - things you should replace while your there
07-31-2019, 10:10 AM | #1 |
471
Rep 996
I am realizing a simple purchase leads to “I might as well replace this while I’m here...”
For example:
What other single mods have turned into a full blown job for you? |
07-31-2019, 10:51 AM | #2 |
398
Rep 1,579
Heater hoses while the intake is off. But only if you are an older E90. Mine were soft in the area under the air filter box from previous owners oil leak(s).
07-31-2019, 11:58 AM | #3 |
118
Rep 272
Replace worn brakes -> Performance brakes -> SS brake lines -> M3 Subframe mounts (since you are pulling the brakes and breaking the line to drop the subframe).
I put the kibosh on an LSD and refreshing sway bar bushings/upgraded swaybar. |
07-31-2019, 01:11 PM | #4 |
Art Collector
2425
Rep 3,448
Check tire inflation > Lug nuts > Forged wheels > LSD > JB4 > M3.
When I'm dead, just throw me in the trash.
CTinline-six6849.00 Thorin117.50 |
08-01-2019, 05:52 AM | #5 |
17315
Rep 18,737
Read on internet E90 water pump fails at 100,000 miles: replace water pump>replace thermostat>replace coolant reservoir>replace all cooling system hoses>replace cooling fan>replace radiator>replace heater core (requires removal of dashboard)>replace AC evaporator>replace ac compressor>replace ac condenser and dryer.
It's a BMW so it must be kept 100% new at all times or it is not perfect.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
08-01-2019, 05:55 AM | #6 |
17315
Rep 18,737
Fixed it for you
08-01-2019, 05:56 AM | #7 |
17315
Rep 18,737
Stop reading Mike Miller's guide to the Universe...
CTinline-six6849.00 |
08-01-2019, 09:06 AM | #8 |
2188
Rep 5,002
08-01-2019, 09:13 AM | #9 |
Hoonigan
6849
Rep 3,000
Drives: '09 328i, '98 Wrangler
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
