Did something stupid...
07-30-2019, 12:14 PM | #1 |
31
Rep 112
Drives: 2011 BMW 335i Sedan
Yesterday I had to jack up my e90 to do a coolant flush. The jack stands were adjusted to its highest position so it's easier for me to work on. After I'm done working, I jacked the car up higher by its front central jack point so I could lower the stands. After the stands were adjusted, I lowered the car, but the jack dropped so quickly that the car slammed right on the jack stands (and it dropped from about 6 inches above the stands). Also clarifying that it was the side jack points that slammed on to the stands, not anywhere else that is not meant to take pressure. I don't know if that caused any damage to the frame... In addition, the metal central jack point is bent, does anyone know where i can get that part?
07-30-2019, 04:01 PM | #2 |
3058
Rep 3,910
Part #5:
https://www.realoem.com/bmw/enUS/par...&q=31116768714 Make sure that part is correct for your VIN. I bet a breakers or eBay will be best - a used one shouldn't be expensive. |
theslowe9031.00 |
07-31-2019, 07:32 PM | #3 | |
31
Rep 112
08-01-2019, 01:54 AM | #4 |
3058
Rep 3,910
Nope. I'd say your car will drive 100% fine as it is. The jacking point on mine is damaged too. Obviously I haven't seen the damage on yours, so I could be wrong.
08-01-2019, 05:45 AM | #5 | |
17314
Rep 18,737
Where exactly is it bent?
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
08-01-2019, 08:02 AM | #6 |
31
Rep 112
The only visible damage would be the plastic jack point being a little misshapen, but I know I can get that replaced. The thing that worries me is if the metal structure is going to be fine.
08-01-2019, 08:06 AM | #7 |
31
Rep 112
It is bent right on the rectangular metal part (front central jack point). I believe when I was jacking the car up, the jack wasn't exactly centered which causes it to bend...
08-01-2019, 11:55 AM | #9 | |
17314
Rep 18,737
Now, what do the plastic lifting blocks (on the side valence panels) look like? I'd bet the walls crushed a bit dropping the car down onto the lowered stands. The lift blocks are replacable. |
theslowe9031.00 |
