Are E90 N51 and N52 valve covers the same?
07-29-2019, 08:51 AM | #1 |
12
Rep 112
I need to change the valve cover on my wife’s 2011 328xi. It has a N51. I have changed the valve cover on my 328xi with a N52. I have looked to see if there are different part numbers for the valve covers but cannot find anything definitive. Do they use the same valve cover?
Also, is there trustworthy aftermarket ones available or do I stick with OEM. Hers is warped which I hear is a known issue. I changed the gasket a few months ago and it was fine for a while and started leaking again. I had the same issue with mine and it actually turned out where the air passages where starting to break loose and it was causing a vacuum leak. We have nearly identical mileage on our cars so I figure it is a good time to just put on new. Last edited by Ironhead Dave; 07-29-2019 at 08:56 AM.. |
07-29-2019, 08:36 PM | #2 | |
Rep 4
Re: N51 & N52 difference
07-30-2019, 01:37 PM | #3 |
12
Rep 112
I have changed the gaskets on both already so I am familiar with the Valvetronic system. Thanks for the heads up though. It can really mess things up if it is not right.
