Blown coolant hose fitting
07-28-2019, 06:26 PM | #1 |
382
Rep 891
Hi all, my e90 finally got me stranded and blew a coolant hose, more specifically, that notorious plastic fitting which goes to oil filter housing. Do you suggest getting OEM plastic fitting or do you recommend getting an aluminum replacement part? What do I need to check after I replace this part to make sure this wasn’t caused by some other issue like dead water pump etc? Pics:
09 328i TiAg 6MT barebones with sport package
07-28-2019, 07:18 PM | #2 |
2440
Rep 4,330
the plastic one only comes with the complete line, and you don't want to pull it all apart. that line goes round the whole motor on mine.
buy an aluminum one, crunch the old plastic in the line with some pliers, pull out ALL the chunks. be certain. Install new piece with some coolant for lube on the o ring and a hose clamp on the rubber hose. done. if all you got was the low coolant light and no overheat light, the rest of it's probably fine. |
07-28-2019, 11:08 PM | #4 |
382
Rep 891
any particular aluminum fittings I need to be looking at or any kind of ebay/amazon generic fitting will do?
07-29-2019, 12:26 AM | #5 |
382
Rep 891
On a side note, which coolant hoses are under pressure and/or can get you straned and which ones usually leak slowly or don't leak at all because they are not exposed to a lot of pressure and don't degrade over time?
07-29-2019, 01:09 AM | #7 |
382
Rep 891
is this the hose this video is talking about?
https://www.realoem.com/bmw/enUS/sho...diagId=17_0350 number 7 on this part diagram
07-29-2019, 05:48 AM | #8 |
17317
Rep 18,740
This should help:
https://www.e90post.com/forums/showthread.php?t=1618232 There are several manufacturers and/or sellers of the aluminum hose bib part. There is a plastic one available too, but why bother. Amazon has several sources for the aluminum version. The DIY above provides part numbers.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
CTinline-six6849.00 |
07-29-2019, 05:57 AM | #9 |
17317
Rep 18,740
OP, if you replace the upper return line that goes across the top of the radiator to the coolant reservoir, be really careful removing it from the upper radiator hose. The small bib the hose attaches to can easily be snapped off. The hose is attached using a crimp clamp, so it's a PIA to remove the clamp and not snap off the little hose bib.
07-29-2019, 03:03 PM | #10 | |
382
Rep 891
Another question-how acceptable is it to top it off with green coolant? It’s going to be there temporarily since I decided that I should not postpone the water pump and thermostat replacement. |
07-29-2019, 04:27 PM | #11 | |
17317
Rep 18,740
07-30-2019, 01:47 AM | #12 |
382
Rep 891
It's alive!
Well, I couldn't wait and when I discovered some oreilleys locations sell this aluminum coolant fitting made by Rein, I went there and bought it as well as the replacement hose just in case. Got the fitting replaced, it was a lot worse than I thought - it also was desintegrated on the inside, had to pull it out piece by piece and had to clean the housing as well. Used up my pentosin pentofrost nf coolant bottle as well as some of the bmw coolant i stashed up for the upcoming water pump job. Oh well. Car sounds healthy and pulls strong, no issues after 5 mile test drive (hwy + city). Very happy to have it driveable again. fitting: https://www.oreillyauto.com/detail/b...nt+hose&pos=14 and the hose: https://www.oreillyauto.com/detail/b...bmw/328i?pos=6 Last edited by fastboatster; 07-30-2019 at 02:07 AM.. |
07-30-2019, 10:00 AM | #15 |
2440
Rep 4,330
mine is in the back, I'm at 148K. I had to replace the upper radiator hose because I broke off the little nipple with the steam line that goes across the radiator.
07-30-2019, 12:05 PM | #16 |
382
Rep 891
So it drove to work totally fine, however, halfway through, I discovered that there’s no heat. So there’s still some air in the system. I think what I did wrong was that I didn’t let any coolant to bleed from the bleed screw. Will have to do it after work, will top off the coolant and bleed the system again
07-30-2019, 11:11 PM | #17 |
382
Rep 891
Small problem, still no heat. Topped off coolant all the way up to the bottom of the filler neck, opened bleeder screw and got fluid with no bubbles coming out. Tried to bleed the circuit, not sure if the water pump Actually worked for whole 12 minutes. After first bleeding attempt, coolant level didn't decrease.
What am I doing wrong? Pressed on the gas pedal for 10 seconds, did hear some sounds as if the coolant is flowing through the pipes. Which gear should I be in if I have a 6 speed manual? Should I be in neutral or in gear? Did one more bleeding attempt, no fluid level change. Drove home, car seems fine but there's no heat. P.S. - my current guess is that the thermostat got stuck because of the debris from disintegrated fitting. Will check that tomorrow by monitoring coolant temp in the hidden menu. Last edited by fastboatster; 07-31-2019 at 12:41 AM.. |
07-31-2019, 12:51 PM | #18 |
382
Rep 891
Nope, no stuck thermostat - temp doesn’t drop off on the hwy. instead, it goes up when i’m cruising with light throttle and goes down when I get on the gas. Temp is about 90C when pushing on it and 96-98, maybe 100c when cruising. Seems like normal mapped thermostat behavior.
Might be wrong, there’s some warm air now, will double check again and recheck the coolant level after work again |
07-31-2019, 01:36 PM | #20 |
1209
Rep 2,476
Don't know what engine you have, but for N54 E9x there is a coolant bleed procedure that is needed after any repairs like what you did are done. I assume it's same/similar for non N54 cars.
Google it for the procedure, if you haven't already. |
07-31-2019, 01:41 PM | #21 |
382
Rep 891
Yep, performed that procedure 2 times.
07-31-2019, 05:27 PM | #22 |
2440
Rep 4,330
did you have the car hooked up to an external power supply when you bled it?
it should run for 10+ minutes making all kinds of different pump speed noises. |
