Keyfob stopped working...
07-28-2019, 05:27 PM | #1 |
15
Rep 184
Hello,
I recently had a tire replaced and upon getting my car back, my key stopped working. I replaced the battery to no avail. Does anyone know what could have gone wrong or what I should do to fix my problem? Thanks! |
07-29-2019, 01:04 PM | #2 | |
494
Rep 1,416
07-29-2019, 05:47 PM | #3 | |
15
Rep 184
07-30-2019, 08:22 AM | #4 |
494
Rep 1,416
Door actuators. Does the central locking button work consistently? meaning get in the car and unlock and lock the doors 10 times. Does it click lock and click unlock each time? or is it sticking some of the the times?
08-07-2019, 05:13 PM | #5 | |
15
Rep 184
08-07-2019, 05:16 PM | #6 |
69
Rep 656
I had this happen to me last month, even though BMW says that the key fobs are charged while driving I doubt that because of what happened to me. Long story short, I used my spare key and the car would unlock and lock remotely like it's supposed to. For some reason my key fob just ran out of juice or whatever. It still worked if I put it in the ignition and started the car. I have no idea why this is though...
FBO + PURE STAGE 2 + MHD FLASH
08-07-2019, 05:20 PM | #7 | |
15
Rep 184
08-09-2019, 01:38 PM | #8 |
69
Rep 656
Sorry to hear that man. I hope you get it figured out as I have no idea what could be happening? Maybe the receiver?
08-09-2019, 01:48 PM | #9 | |
15
Rep 184
08-09-2019, 06:02 PM | #10 |
69
Rep 656
I think, if I am remembering correctly, near the third brake light on the rear windshield. Try that and see if it works or just got to a local BMW indy. Don't go to the dealer.
08-10-2019, 12:11 AM | #11 |
34
Rep 295
Have you tried to resync/reprogram it yet? It's possible the battery died, then after you put the new battery in, it lost memory and needs to be resynced to the car. I've heard that these keys resync once you put them into the slot in the car, others have said you need to program them. I will try to find the procedure. What model car is yours?
Also, if you find out what is wrong with it, please post the results. Thanks Last edited by Kaz26; 08-10-2019 at 12:18 AM.. |
08-10-2019, 12:54 AM | #12 | |||
2704
Rep 4,034
https://www.newtis.info/tisv2/a/en/e...te-key/vSvyPqq Here's the F63 circuit; if F63 blown, you would have NO gear lighting (on left of shift lever): https://www.newtis.info/tisv2/a/en/e93-335i-cab/jeQATDZ In the sedan & wagon, the Aerial Diversity, located above the rear glass, contains the FBD Receiver, but that does NOT appear to be the case for the Convertible. Here's YOUR Aerial Diversity circuit: https://www.newtis.info/tisv2/a/en/e...memory/jVv0rwL Please let us know what you find, George |
08-10-2019, 12:57 AM | #13 |
15
Rep 184
Welp... my issue has been solved.
I had my rear view mirror harness unplugged due to an issue I was having and apparently that was the cause. I was working on the mirror today and plugged it back in... this immediately solved the problem. Sorry for wasting everyone's time, but I appreciate all of your help. Thanks! |
