BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Engine oil service
      07-27-2019, 08:17 PM   #1
adi555
21
Drives: F48
Engine oil service
Would like to know when the engine oil service light goes up, what all parts are to be changed/serviced?
      07-27-2019, 08:27 PM   #2
Skyline2.0
137
Drives: 2018 BMW X1 xDrive
5.25 L of oil, paper filter, drain plug washer, plastic oil filter housing plug, and oil filter housing O ring. Afterwards, reset maintenance light.
      07-28-2019, 03:33 AM   #3
adi555
21
Drives: F48
What about oil filter, air filter? Also greasing of suspension or anything else? Because my other car (Audi) had a lot of things done whenever the car went for oil change service. The workshop guys would do complete check, grease the doors, suspension, etc.
      07-28-2019, 10:46 AM   #4
Skyline2.0
137
Paper filter as in oil filter (it's made of a paper material as opposed to replaceable spin on metal kind on other cars). X1 stock suspension parts do not have grease fittings. The cabin and engine air filters should be changed as needed. Not necessarily at every oil change.
      07-29-2019, 05:23 PM   #5
adi555
21
Drives: F48
Thanks! Does the car have sensors to detect Air/Cabin filters if change is necessary?
      07-29-2019, 07:17 PM   #6
fongpei
Drives: 2016 X1
good to know. Thanks.
      07-29-2019, 09:14 PM   #7
Skyline2.0
137
No sensors. With factory filters, the best way to verify whether either needs to be changed is with a visual inspection.
However, if you're bringing it in to the dealership or independent mechanic, you may want to refer to the recommended intervals in the attached guides - inspect every 15k miles; replace, as needed, every 30k miles. Again, replacement interval would depend on how dirty each filter is. If you bring it to a shop without checking yourself, you'll have to rely on another person giving you an honest response.
I use K&N filters for both cabin and engine, which I inspect every about 6-8 months or 10-12k miles, whichever comes first. I follow K&Ns recommended cleaning procedure with their products. K&Ns intervals wouldn't apply for BMW factory filters.
File Type: pdf Alternative BMW Maintenance Schedule.pdf (421.9 KB, 239 views)
File Type: pdf BMW Lifetime Maintenance Schedule v03.13.pdf (618.1 KB, 216 views)
      07-31-2019, 09:01 PM   #8
wcs2229
wcs2229's Avatar
171
Drives: 2018 BMW X1 F48 xDrive28i
I took my X1 in earlier this month for the first no-charge maintenance service (in Canada) at 18 months or 16,000 Km/10,000 mi. They replaced the cabin air filter without doing any visual inspection and said that is according to the Maintenance Schedule. On the other hand, they did not replace the engine air filter and said it lasts longer (at least until the next maintenance interval).
      07-31-2019, 09:53 PM   #9
adi555
21
Drives: F48
Is there any way to get hold of the official maintenance list by BMW. I somehow don't believe the workshop guys and it seems they try to hit their monthly targets
      08-03-2019, 04:17 PM   #10
Ridin'Dirty
Ridin'Dirty's Avatar
60
Drives: '93 'Beemer' R100r, '17 X1(S)
      08-04-2019, 04:35 PM   #11
adi555
21
Drives: F48
[img]https://i.ibb.co/WVLyJ7T/Maintenance-Sch.jpg[/img]
Is this region specific? Could you share the link so that I could look into my region and Diesel engine? Thanks!
xbimmers
