07-27-2019, 11:47 AM | #1 |
127
Rep 170
Gtechniq Ceramic Coating
After having it 2 weeks I finally got around giving the new German mistress a thorough detail. It also gave me a chance to apply a ceramic coating for the first time.
Washed: 2 bucket method with Carpro Reset Clayed to remove any bug guts and contamination from the shipping. Light polish with Meguiars D302 Wiped down with Carpro Eraser to remove any polish oils and residues One coat of Gtechniq Crystal Serum Light Two coats of Gtechniq EXOv4 It feels like glass and looks wetter than a... Portimao Blue FTW! |
07-31-2019, 02:51 PM | #3 |
120
Rep 244
Drives: 2020 BMW M340i xDrive
Nice, looks really good. How easy was the ceramic coating to apply? I'm looking at applying CSL and Exo as well.
07-31-2019, 03:47 PM | #4 | |
127
Rep 170
you will want to make sure: 1) you do any paint correction etc. before applying the CSL. That because once its on its on and tough to remove and will 'lock' in any defects etc. So take the time to get the paint looking tippy top and free of swirls etc. 2) before application make sure you wipe the paint down with some kind of IPA solution (panel wipe, carpro eraser) to remove any polish/wax oils and residues to make sure the coating bonds with the clear coat. 3) work in small sections (I did the hood in 4 sections). Apply with a cross hatch pattern, let sit for a minute or so and them wipe off. it wipes off pretty easy. but you will want to make sure you get it all off/leveled so work in a well lit garage and or use an LED light to inspect each section before moving on to the next one. I recommend a 2 MF towel. One for the initial wipe off to remove most of the product and then a final towel to make sure you get everything. Once you do a couple of panels you'll get the hang of the product. 4) my kit came with gloves. wear them. 5) EXO was a tad bit more difficult to wipe off. It has a little bit more tendency to smear but it still comes off easier than most traditional waxes. I found this helpful |
07-31-2019, 06:05 PM | #5 | ||
120
Rep 244
08-03-2019, 09:03 AM | #7 | |
127
Rep 170
Certainly not enough to do anything (wet sanding) about it. |
10-23-2019, 11:24 AM | #8 | |
44
Rep 114
I was thinking of getting the GTech CSL/EXOv/Panel wipe kit. Because it would be essentially brand new I figured the panel wipe would take off any residue that could be on it from shipping. Then be able to CSL-->EXOv. Thoughts? |
10-30-2019, 08:20 PM | #9 | ||
127
Rep 170
Then after that I'd do the panel wipe and coating. |
