Bimmerpost
4 Series
Technical Topics Wheels and Tires Max tire size M340 Square setup
      07-26-2019, 11:07 PM   #1
kohlzor
Drives: 2017 M240xi
Hey Folks,
Anyone know the max tire size I can fit on a M340xi that came with square setup 19"? Wanted to swap the runflats.
      08-07-2019, 09:41 AM   #2
Booster
Pave The Rainforest
269
Drives: Wagon
2007 335i Coupe  [0.00]
I'm going to try and test fit some 255's in near future
Sold: 2015 Pyrite Brown M3
Sold: 2020 Sunset Orange M340i Xdrive
Sold: 2021 Bluestone 540i Xdrive Msport
      08-19-2019, 05:38 PM   #3
Wmzorba09
326
Drives: Bmw M340 2020
I have 19 on M340 and it came with 225 square all season (Bridgestone) - wanted staggered ( 255 or 245 ) on the rear. Did you ever test fit the rear with 255? I've consulted several on this forum that believe they won't fit and advise against retrofitting with 255's, but uncertain on the 245's.
      08-20-2019, 03:17 PM   #4
pkancel
pkancel's Avatar
Drives: BMWs
For comparison, I have the 20inch BMW forged wheels and I put 235/35-20 fronts and 265/30-20 rear. vs what BMW put which was 225-35 and 255/30. Mine have room still but obviously I didnt want to throw off my spedo too much.
Wmzorba09325.50
      08-30-2019, 12:23 PM   #5
dariusX
Drives: 2020 BMW M340I XDrive
I wonder if running 245/40/19 squared would cause any rubbing? Or any downsides in particular?
      08-30-2019, 06:40 PM   #6
tnsatbhs
tnsatbhs's Avatar
Drives: 2020 BMW M340i xDrive
Interested in this as well. Surely someone has tried this setup.
      09-05-2019, 12:05 AM   #7
Transfer
Transfer's Avatar
5254
Drives: Bronco Wildtrak, Tesla MYP
I'm thinking towards winter tires and sizes are limited. I'm leaning towards 235/40/19 squared but could consider 245s or 255s if they'll fit up front. Bump for any measurements or test fits!
      10-04-2019, 12:32 PM   #8
jahudini
Drives: BMW M340 Xi. BMW M3 G80
255/35/19 Fits
I have a 225/40/19 - 255/35/19 Rear and i have no problem, fits perfectly. Mind you i have a 10mm lowering.
Am considering 235/40/19 - 265/35/19 next. With what i have noticed i can push 265 rear....i am certain with confidence cos i have weight in my trunk with this set up....don't ask why....i hit curves at 90+ miles.
I belive with 235/40/19 - 265/35/19 the car will look bastardly insanely beautiful.
      10-08-2019, 07:35 PM   #9
kohlzor
Drives: 2017 M240xi
This is on the staggered stock rims correct?
      10-12-2019, 10:32 AM   #10
jahudini
Yes it is.
      10-20-2019, 05:50 AM   #11
Who's on first
Who's on first's Avatar
Drives: A-10C
I'm going to throw on 245/35/19's on my Square 792M's.
SHOULD be just fine, we will know this week.
      10-20-2019, 07:15 AM   #12
BarryB
BarryB's Avatar
Drives: 30Jahre M5 plus a few more M's
I have 245/40 19 in front on the stock 8" rim no prob.
Current non-BMW's
20 Jeep Grand Cherokee
03 Cooper S (Maxi Tuned 50bhp)
60 Impala (43k orig mi)
15 Turbo S (Kobb tune and Kline exhaust)
      10-20-2019, 08:35 AM   #13
Who's on first
Drives: A-10C
They are 8.5" wide...
I'm just curious why did you go with the 40 series instead of a 35.
Do you have any pic's by chance?
      10-20-2019, 08:37 AM   #14
BarryB
BarryB's Avatar
They are 8" wide from the stock 225 run flats for sure.
I wanted less gap so a taller tire helps with that and better for potholes.
I purchased 2 8.5" rims for the rear and have 265/35 on there.
Pics once I get home and pick up from the dealer.
Current non-BMW's
Appreciate 2
      10-21-2019, 10:32 AM   #15
BarryB
BarryB's Avatar
Here are some pics from my parking lot this am after pick up i have one stock pic (last one, before tint and front splitter. )Black wheels are hard to see in the pics but the best I have so far.
Still need spacers, I think.....
Gap is WAY better in person.
Current non-BMW's
Appreciate 9
      10-23-2019, 04:37 PM   #16
kohlzor
Drives: 2017 M240xi
245/265? No issues with x drive?
      10-24-2019, 12:15 AM   #17
BarryB
BarryB's Avatar
265/35
Nope or at least per the dealer and from what I can tell so far. They feel great. 265/40 on the other hand DID NOT work.......
Current non-BMW's
MAKH 588.50
      10-24-2019, 09:29 AM   #18
NeverEnough007
43
Drives: 2020 M340i & 1991 Mtechnic E30
Looks excellent!
      11-05-2019, 04:08 PM   #19
rparker35
rparker35's Avatar
22
Drives: 2020 M340i xdrive
My M340i xdrive also came with the 225 square all season setup.
I would like to swap out the tires for the Conti DWS06 as I have run those on several cars and loved them.
They do make the DWS06 in the stock size (225/40/19), but thought about going with something slightly wider like a 245 series.
BarryB said the 245/40/19 size fits on the stock 8-inch rim, which I assume is what I have on all 4 corners with the stock square setup.
Any thoughts on going with 245/40/19 for all 4 tires?
Appreciate 2
      11-07-2019, 08:54 AM   #20
BarryB
BarryB's Avatar
Correct, I have those on my stock front 8" rims with no issues.
Current non-BMW's
      11-07-2019, 06:18 PM   #21
tnsatbhs
tnsatbhs's Avatar
No issues with rubbing even at full lock? You mind posting some pics so we can see how the 245s look on the 8" wheel?
      11-07-2019, 11:32 PM   #22
DanVlnStud
DanVlnStud's Avatar
40
Drives: 2020 BMW M340i XDrive
This is what they told me at VMR
The recommended fitment for your car is going to be 19x8.5 ET23-25 in the front with a 225/40/19 tire and 19x9.5 ET35 in the rear with a 255/35/19 tire. This is based on stock to mildly lowered ride height.
2x VMR Wheels V802 19x8.5 ET35 5x112 66.6 $365 (12mm spacer + extended lugs advised)
2x VMR Wheels V802 19x9.5 ET35 5x112 66.6 $365
My current setup is:
Appreciate 2
g20
