BMW X5
      07-26-2019, 02:03 PM   #1
jokinawa
293
Drives: 2019 X7 40i
G05 E-Sys Cheat Codes
Hi All,
I have developed some cheat codes for my G07 which should work for G05 for the most part.
If someone is willing to test and get back to me that would be great.
Here is a link to the post.
[CODING] G07 E-Sys Cheat Codes https://g07.bimmerpost.com/forums/sh....php?t=1636904
And a link to the cheat codes:
https://github.com/packetpilot/bmw-f...s/jokinawa.xml
I am still working on them and will have some updates soon. Cheers!
If my post was informative or helpful, please click the appreciate button. Thank you.
Appreciate 13
      07-26-2019, 10:31 PM   #2
LexxM3
LexxM3's Avatar
1698
Drives: E46M3, G05X5
2019 X5  [0.00]
I'd like to get into this, but while technical and capable, I've never done this kind of thing before, so a coding newb. In anticipation, I've been getting a little bit of the setup to start to play with E-Sys coding and have the Ethernet cable and a Windows PC ready to start to configure the software. If you can point me to a shortcut for the software setup, it would save me time to figure out myself.
My car is a Canadian late April 2019 production G05 X5 40i with the options you can see detailed in my profile.
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
      07-26-2019, 11:30 PM   #3
jokinawa
293
Drives: 2019 X7 40i
Sent you a PM
Appreciate 2
LexxM31697.50
      07-27-2019, 04:50 PM   #4
archivedaccount
Guest
n/a
Drives:
Great news.
Does latest launcher pro have fdl mappings for the new G05/G07 modules in including MGU?
Is Eli finally responding to new token requests?
      07-27-2019, 05:54 PM   #5
jokinawa
293
Drives: 2019 X7 40i
Originally Posted by eaglesrest View Post
Great news.
Yes and yes.
I just got Video in Motion unlocked today and updated the cheat code list. Waiting for the changes to be merged from my repo.
      07-28-2019, 06:21 AM   #6
marcosg
marcosg's Avatar
Australia
25
Drives: 2024 G05 X5 M60i
Originally Posted by jokinawa View Post
Yes and yes.
Thank you @jokinawa for starting this thread. I also just coded the VIM and it worked great
      07-30-2019, 05:12 AM   #7
archivedaccount
Guest
n/a
Drives:
Yes, thanks jokinawa.
I've tested mode startup and tire pressure with temps and all work great
Not had chance to test VIM yet. I did notice that the iDrive UP with Media/Home key press, did not do anything. I notice your screenshot shows US: Speedlock ...... I have a UK car so maybe that's the difference?
Marcosg - did you have to do the iDrive key mapping to get VIM to work in Australia?
Next challenge ... enable Auto lane change assistant for UK cars
      07-30-2019, 05:17 AM   #8
marcosg
marcosg's Avatar
Australia
25
Yes, I did. Once, I coded MGU, I followed the key mapping as described and it worked straight away.
      07-30-2019, 06:28 AM   #9
archivedaccount
Guest
n/a
Drives:
OK thanks, and you got the US-Speedlock screen that OP showed? Doesn't sound too promising at my end then.
I coded VIDEO SPEEDLOCK CONDITION and the SPEEDLOCK VALUES (Max/Min), but the idrive controller adjustment didn't do anything
      07-30-2019, 06:32 AM   #10
marcosg
marcosg's Avatar
Australia
25
You will need to set "SPEEDLOCK_FREISCHALTMENU" to aktiv to get the pop up screen.
Appreciate 2
      07-30-2019, 06:36 AM   #11
archivedaccount
Guest
n/a
Drives:
Re Lane Change Assistant for UK cars. I managed to get the Lane Change Assistant option to present in iDrive but it's greyed out, which means there are 1 or more other coding options required for the feature to become applicable.
On other models I believe this option is SAS10-C_SWA_VORHANDEN, however G05 does not have SAS10 module anymore. Anyone know what the alternative is? I've tried searching each module but can't find the option
      07-30-2019, 06:40 AM   #12
marcosg
marcosg's Avatar
Australia
25
What coding option did you set to get the Lane Change Assistant option in iDrive. Thank you.
      07-30-2019, 07:09 AM   #13
archivedaccount
Guest
n/a
Drives:
That worked! Thank you
      07-30-2019, 07:11 AM   #14
archivedaccount
Guest
n/a
Drives:
HU_MGU --> Spurwechselassistent set to gen1
      07-30-2019, 10:23 AM   #15
bichoo
bichoo's Avatar
281
Drives: BMW X5 40i M-Sport
Hi All,
Thanks for this great work. I just heard back from tokenmaster finally so i'll be poke around as well to see what more stuff I can find as well. RGSport already enabled a bunch of items for me remotely: anti-dazzle, VIM, remove legal disclaimers, M logo startup, remote trunk close, enable trunk closing noise always.
I look at your XML, what's with the Comfort Individual and Comfort Individual? Are these additional customizations available? I'm in a G05 so perhaps its G07 specific? Thoughts?
2019 BMW X5 40i Phytonic Blue/Tartufo
2016 BMW X3 35i M-Sport, Dinantronics (sold)
2012 BMW X3 28i (sold)
      07-30-2019, 12:32 PM   #16
jokinawa
293
Drives: 2019 X7 40i
Hi All,
Those are additional driving modes.
Unfortunately I haven't figured out how to get Comfort Individual to display in the HU. Comfort Plus and Sport Plus do.
bichoo280.50
      07-31-2019, 06:52 AM   #17
jokinawa
293
Drives: 2019 X7 40i
I have sent an email to Stephan of BimmerCode offering to help get all of these options into his app to make it easier for others to code these options.
Appreciate 6
LexxM31697.50
SWBOS48.00
eagle_bmw182.50
VTENGR1043.50
      08-01-2019, 08:05 PM   #18
motex
2020 Mineral White 30d MSport
motex's Avatar
Costa Rica
521
Drives: 2020 Mineral White 30d MSport
Thanks man for your usual colaboration
I drive a 2016 F15 30d fully coded with Bimmercode, great app!
Now I'm waiting for a new G05 on around middle of Sept and would love to code it with Bimmercode, E Sys coding is not for me
....Life is too short to drive boring cars
      08-01-2019, 11:06 PM   #19
jokinawa
293
Drives: 2019 X7 40i
No problem. Stephan, the BimmerCode dev said he is looking into the info I sent him. Fingers crossed.
      08-03-2019, 01:51 AM   #20
marcosg
marcosg's Avatar
Australia
25
Show contact pictures in iDrive from connected phone contact list.
HU_MGU -> PIM_BILDER_EIN_AUS set to Aktiv.
Appreciate 2
jokinawa293.00
      08-04-2019, 05:46 AM   #21
marcosg
marcosg's Avatar
Australia
25
Ability to view text messages, control messages and Widget setup screen whilest in motion (up to 63km/hr only), the following codes are in HU_MGU
SPEEDLOCK_SPEEDVALUE_MIN set wrete value to 1F
SPEEDLOCK_SPEEDVALUE_MAX set wrete value to 3F
SERVICES_MESSAGES_SPEEDLOC_CONDITION set to none
SPEEDLOCK_CAR_STANDSTILL set to none
SPEEDLOCK_TEXT_LENGTH set to whole_text
Note: This will NOT affect VIM coding.
      08-21-2019, 12:58 AM   #22
Almaretto
Almaretto's Avatar
2373
Drives: Test Vehicles
G05 can have 42C1 SAS
View post on imgur.com
There is also 3D14 IB CT01 VIP.
SPEEDLOCK_SPEEDVALUE_MAX set wrete value to 0F
Did you try setting max to 3F?
Search this Thread:
Advanced Search
xbimmers
