Front pads sensor help
07-26-2019, 11:20 AM | #1 |
16
Rep 67
Hey Guys , just done front pads / discs on 330i m sport . I didn’t replace the pad sensor . I now have the car on a lift symbol and brake symbol lit . Can I over ride this without replacing a new one to make dash lights go off ? Please help Thankyou
07-26-2019, 12:28 PM | #2 |
5518
Rep 5,440
Drives: Beige G31 40ix m sport
Car on a lift symbol means the annual inspection (mot in English) is becoming due, just go into the menu and reset the date for when the next mot is due.
Most likely just a happy coincidence getting that symbol after doing the brakes.
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
07-26-2019, 12:45 PM | #3 |
16
Rep 67
Thanks for reply . Brake light still on dash , what’s easiest way to get it off . ? Code reader ? Join the wires to make circuit ? Or is only option new sensor thanks
07-26-2019, 01:26 PM | #4 |
21
Rep 41
Yes you can join the wires or replace the sensor. Last time I did mine I joined the rear pad sensor and used a new front. Reset the pad life monitor and been fine since.
07-26-2019, 02:34 PM | #5 |
5518
Rep 5,440
I didn't notice in your first post that you had a brake warning light as well.
Yes you could bodge it but sensors are cheap & if your capable of changing the pads, fitting a sensor shouldn't take you very long
G31 40ix M Sport
07-26-2019, 05:08 PM | #6 |
106
Rep 576
As Chappers says genuine BMW sensors are cheap as chips so why not just replace it and have a useful feature of your car working rather than bodging something to fool the ECU?
What discs / pads did you fit? When I last did mine I was asked if I wanted a sensor as they are either worn out or you break them when removing them from the pad; which is what I did incidentally! |
07-29-2019, 12:02 AM | #7 |
243
Rep 2,026
maybe the garage broke the old sensor,,or its worn ,,i never let pads get very low so no need for sensor change,,but can still wear if brakes have bad inner wear which is hard to see,,id get a new sensor,,as said pretty cheap
07-31-2019, 01:38 PM | #9 |
16
Rep 67
Joined the wires on old sensor , sorted problem . I’m savy enough not to rely on a sensor anymore! Can see when pads down low hey ! Thankyou for everyone who helped .
07-31-2019, 05:18 PM | #10 | |
106
Rep 576
Just seems strange that you do not want to spend a few quid on a brake wear sensor but you keep asking us if you should replace all of your coil packs when you don't even know if any of them are faulty |
