07-23-2019, 06:30 AM | #1 |
171
Rep 468
Bilstein B12 Pro F30 XDrive fitted with Photos
So after a few months of research, I decided to modify my 335XD suspension as in the standard form the setup was horrible. Too high, unstable, bouncing and pretty much downgrading such a capable car. After a few high speed drives I just didn't feel safe in my car due to so much waving.
Did my research, B6,B8,Eibach,ACS,KW,H&R and then B12 from Eibach/Bilstein. I am so glad I didn’t just go for springs only after seeing how much of a let down the dampers are. The B12 kit compromises of B8 dampers coupled with Eibach Springs 06-22. The only difference is I choose 05-22 springs from Eibach, which are around 5mm lower. ( Bear in mind this spring is the same as ACS F30 XD spring) Fitting was easy, it's a direct replacement, no major dramas. Checked the alignment afterwards and it was all as before, no change as excepted and all within BMW tolerance. Now for the drive, what can I say. This setup is a must!! Why BMW didn’t supply the car like this, I dont know. The handling is just amazing, the car has a better stance, no more body roll, the steering is tack sharp and most importantly the comfort hasn’t t been compromised. ( this was the only fear I had, as with my previous cars on coilovers, the handling is good but the ride can be pretty tough which is not the case with B12's) To give you an idea, the comfort level is similar to factory Msport suspension, but with less bounce. These dampers are amazing. The rebound rate is really good, which is greatly felt when going over dips on the road where before the car would bottom out and then bounce on the springs. The standard dampers when compressed take forever to return back up, so essentially you are just bouncing on the springs, while B8's when compressed return to default high almost instantaneously. Height Drop: Car was measured before from the bottom rim to the arch of 645mm +/- all around. Now reads front 625mm and rear 623mm, so overall 20/25mm of a drop. See photos: |
07-23-2019, 03:18 PM | #2 |
65
Rep 240
Wow! It looks fantastic! The F30 with this suspension and M Sport kit is absolutely handsome and now has excellent suspension to boot with the B12 Kit. Thank you for posting the pics and the detailed report of how it handles.
xpro171.00 |
09-05-2019, 11:51 AM | #4 |
171
Rep 468
https://md-performanceparts.de/
Got them from Germany. Top notch people to deal with. They have an ebay store or you can email directly. I emailed them and paid via PayPal |
09-08-2019, 03:15 PM | #6 |
171
Rep 468
Definitely too low. If you have a front M performance spoiler I would rather go higher then not being able to go over bumps and ramps.
01-13-2020, 10:02 PM | #7 |
873
Rep 1,079
Images are no longer available Did you use the stock rear bumpstops? I think B12 kit comes with bumpstops in the front but we need to reuse the stock ones in the rear? Some people have suggested using the shorter bumpstops in the rear.
01-13-2020, 11:32 PM | #8 |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Since the B12 uses Bilstein front struts (which have an inverted design) they have their own internal bump stops.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
thatBimmerBloke872.50 |
01-13-2020, 11:48 PM | #9 | |
873
Rep 1,079
By the way, subscribed to your YouTube earlier, you should make a video about B12 kit too |
01-14-2020, 11:54 AM | #10 | |
4017
Rep 3,540
If someone brings me a car with B12s I'll make a video on how I feel it rides lol. If I were to design a B12 kit I'd pick stronger springs than Eibach uses. At least the B12 kits maintain flat ride.
01-14-2020, 12:01 PM | #11 | |
873
Rep 1,079
Thanks. |
01-14-2020, 12:59 PM | #12 |
4017
Rep 3,540
That depends on your car and weight. You'd definitely want a stiffer front spring with the extra weight of the 6cyl engine vs my 4cyl. You might even consider seeing what kits/spring rates they have for the F33 (which is the heaviest F3x).
01-15-2020, 09:11 AM | #13 | |
873
Rep 1,079
Maybe alohasurftoad can chime in too |
01-15-2020, 08:32 PM | #14 | |
480
Rep 681
2016 328ix F31 - SOLD!
2006 997.1 C4S |
