07-22-2019, 10:52 AM | #1 |
1478
Rep 1,286
Anyone tried Caliper Wrap Film
Trying to improve the look of the ugly stock calipers. Wondering how this would work:
Rvinyl 3M Caliper Wraps Reflective Vinyl High Heat Temperature Film (Light Blue) 4 Sheets x (12" x 12") W/App Card https://www.amazon.com/dp/B07N8JPCDS..._kRDnDb9CSHZQZ Or would it be easier and safer to just paint instead? Last edited by McLaren720s; 07-22-2019 at 02:06 PM.. |
07-22-2019, 11:26 AM | #2 |
8245
Rep 16,088
Never tried it. I do use this, which works very well, and is easy to touch up. The price is right too.
https://www.amazon.com/PlastiKote-CP...4&sr=1-11&th=1 |
07-22-2019, 02:06 PM | #3 |
1478
Rep 1,286
I was also looking at caliper covers but not sure if they fit
4 BLUE BMW M Power Brake Caliper Cover Disc Front Rear 330 335 340 530 540 550i https://rover.ebay.com/rover/0/0/0?m...2F132920646445 |
07-22-2019, 02:52 PM | #4 |
Modder of everything I own
147
Rep 491
I painted mine on the car, it actually went really well, looks great and the paint has lasted through 2 winters already. I think vinyl is a PITA on irregular surfaces.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
07-22-2019, 03:15 PM | #6 |
¯\_(ツ)_/¯
945
Rep 1,762
The covers look tacky and I wouldn't trust vinyl on brakes. Take the brakes off, clean them, sand them, base coat and clear coat
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
07-22-2019, 04:53 PM | #7 |
2025
Rep 2,806
Drives: F33 430 and F39 M35i
Or even lazier method. Mask off rotor and spray calipers. Took longer to mask than to spray. I used blue plastikote.
07-22-2019, 09:39 PM | #8 | |
4528
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
d_a_m92.50 |
07-23-2019, 10:41 AM | #9 | |
1478
Rep 1,286
Plus, they’re incredibly ugly, especially the rear. |
07-23-2019, 11:08 AM | #10 |
8245
Rep 16,088
This is how my front caliper looks after painting. I kept it the original silver color:
It might not win a best in show beauty contest but it looks a lot better than it did before I painted it: |
07-23-2019, 04:01 PM | #11 | ||
4528
Rep 5,392
G2 is a two-part epoxy type paint. It goes on thicker with a much more solid pigment that fills surface imperfections. The finish really flows. It is definitely not thin like spray paint. A better spray paint analogy would be if you sprayed 3-4 coats of a primer filler before you sprayed that final coat or two of color. I attached a photo of a rotor that I brush painted with G2 Silver Caliper Paint. Only the visible sides of the rotor hat are painted. I didn't paint the tops of the rotor hats because I read a couple engineers caution against a coat of anything between the rotor hat surface and the inside wheel surface where they contact each other because the coating could compress and effect the final torque of the wheel bolts. I think you can see that the silver painted area on the sides of the rotor hats looks much better than any simple spray paint. And a year later on the car, they look just as good as they did the first day. Hope this helps! |
d_a_m92.50 |
07-24-2019, 02:29 AM | #12 | |
1309
Rep 6,311
I had mine painted by BMW (on previous car and current car) for about 300 dollars, with warranty for 2 years. This of course included brake fluid change etc.
I really can't say I advocate these hand painting methods or wraps on that part of the vehicle. Get it done right. Also - if you want flashy brakes (mine are small and were painted dark grey, just not rusty) - go source some 2 piston ones in 370mm from bigger engined cars (and get coding for that done of course!). I wouldn't bother with these cheap mods on cars as nice as yours... IMHO best bang for buck is these bigger brake upgrades. I just didn't plan to part my car out later, so I upgraded the look of existing parts, but for most the bbk upgrade using second hand or new parts is the best way to go. If you have big brakes - just paint them right. Quote:
Happy to post mine later today. They look very ok IMHO painted.
F30.F11.E86.E90.E90.E36 |
07-24-2019, 04:57 AM | #13 |
2025
Rep 2,806
Plastikote blue on the caliper and black on the hub.
The blue was done in May about 3k miles ago. The hubs I did two weeks ago. I should’ve painted them before I did the brakes but I didn’t think about it till afterwards. |
d_a_m92.50 |
07-24-2019, 11:29 PM | #14 |
93
Rep 177
Looks great!
///437m wheels///Depo Headlights ///3M 1080 Carbon Fiber Interior Wrap///M-Sport Bumper Conversion///Dinan Suspension///M-Style Kidney Grilles
"If we knew what it was we were doing, it would not be called research, would it?" |
07-25-2019, 12:07 AM | #15 | ||
4528
Rep 5,392
370mm are Front 4-piston calipers |
07-25-2019, 02:35 AM | #16 |
1309
Rep 6,311
typo, meant 4 piston yup. thanks!
