07-19-2019, 10:57 PM | #1 |
809
Rep 1,369
Looks like we’re getting CPI next week!
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
07-21-2019, 12:58 PM | #3 |
Cheapskate
4450
Rep 4,993
From a hardware perspective, one taps into the OEM fuel system, and one is an entirely new system of lines, pump, and tank.
From performance perspective, pretty similar since both use external controllers and it's really up to the user on how much they want to lean on the supplemental fueling. Custom tuning will be needd to take full advantage. It's really just personal preference because both systems are pretty proven. Edit: Not really a fan of the injection point, but I guess time will tell. Would prefer hard mounting instead of in silicone, and sems like it could pool up in the turbo. I'd be more inclinde to drill/tap the intake manifold post-Throttle body if there's room. |
07-21-2019, 02:07 PM | #4 | |
659
Rep 1,239
It looks like its hard mounted in an adapter ? |
eluded3043.00 |
07-22-2019, 11:50 AM | #5 |
550
Rep 949
We have an optional coupler which we've been testing on our Pure Stage2 development B58 with good success.
That said we offer the kit without the coupler too for those who want to experiment with placement. You want to keep it a little away from the manifold so it has more room to vaporize and distribute within the air tract. |
kern4174449.50 |
07-22-2019, 12:43 PM | #6 | |
Cheapskate
4450
Rep 4,993
I might be jumping the gun because I'm sure your official release will have more info. I just remember seeing people with meth injection comment on experiencing the same thing when they turned up the flow. |
07-22-2019, 12:56 PM | #8 |
550
Rep 949
No, you can run 91 octane all the way up to straight E85! Although we've found overall E50-E60 is the best mix fro the platform. Maxes out performance while making the tuning end a lot easier than straight E85. Not all the flash maps needed for straight E85 are exposed yet but as they are the CPI kit will continue to grow with you.
eluded3043.00 |
07-22-2019, 12:58 PM | #9 | |
550
Rep 949
kern4174449.50 |
07-22-2019, 07:16 PM | #10 |
650
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
I would be happy to spend 2-3x as much for an upgraded HPFP.
07-24-2019, 09:01 AM | #11 |
34
Rep 124
Drives: 2017 340i M-Sport
Can someone explain to me the differences (other than the obvious one injects meth and one injects fuel from your fuel system) between the systems?
Meth raises the octane rating of the fuel before combustion right? so does using this with pump gas allow for increased boost/timing? I have crappy access to e85 so I'm trying to figure out how to go past stage 2 and would rather not deal with a meth tank if I don't have to. Thanks |
07-24-2019, 10:13 AM | #12 |
550
Rep 949
07-24-2019, 10:15 AM | #13 | |
550
Rep 949
07-24-2019, 10:16 AM | #14 |
34
Rep 124
Makes sense and that's what I kinda figured. Darn, I was hoping to not have to manage another tank.
07-24-2019, 10:54 AM | #15 |
104
Rep 231
Would the gains be worth it or the same results switching from WMI to CPI? Only reason why i would switch is to avoid going out and buying the 5 gallon pail of meth.
07-24-2019, 11:00 AM | #16 |
550
Rep 949
If you already have WMI you're not going to add power changing to CPI, and you may drop power, depending on your octane situation. But it's a much cleaner and easier to maintain setup. With our flex fuel sensor the tuning can automatically detect pump gas vs. e85 and how much e85 and set the tuning all automatically so it's a much easier and more convenient way to make a lot of power.
PURE340i104.00 |
07-24-2019, 12:05 PM | #18 |
550
Rep 949
It remains to be seen what the fueling capacity is of larger high pressure pumps, on the CPI front even the basic single injector setup is good to go for E60 up to 500whp and beyond. It's also probably easier to install and remove. Beyond that time will tell.
eksigned139.00 |
07-25-2019, 06:08 AM | #19 | |
Cheapskate
4450
Rep 4,993
- Cost - OEM upgrades for the hpfp will have less headroom that aftermarket lpfp upgrades - the biggest hpfp will still be limited by the OEM injectors. with the CPI kit you can install larger, easier to find port injectors or daisy chain multiple injectors if you get creative |
eksigned139.00 |
07-27-2019, 11:16 AM | #20 |
32
Rep 72
Should we expect a back end file from mhd or a new one to come out to be coupled with this ? And with e50 e60 with full bolt on and this kit your saying we can get anywhere from 470-500 wheel?
07-29-2019, 07:22 PM | #21 |
550
Rep 949
Our PS2 equipped development vehicle runs E50 and is pretty much maxing out the current turbo with CPI. We are well over 500whp and typically do most of our testing at about 550whp.
To be clear we do NOT use a silicone coupler for our injection mounting point. Our adapter is billet but uses two silicone couplers to mount in the charge pipe where we have removed the factory silicone coupler. Here's a couple pics... Stock coupler Billet CPI coupler CPI kit installed |
kern4174449.50 |
07-29-2019, 07:50 PM | #22 |
650
Rep 2,601
Impressive!
Is that with the stock LPFP? I assume you are running JB4 with MHD BEF? |
