M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Stud Conversion Kit + Spacers
      07-19-2019, 03:12 PM   #1
2PUTT
513
Drives: F87
= Stud kit from Rogue Engineering
= 5mm spacers from Black Forest Industries
(excuse the filthy car)
detailed pics of the install will be shared in my build thread linked in my signature soon.
      07-19-2019, 09:08 PM   #2
bioman
173
Drives: E30
Are longer studs necessary for 5mm spacers?
      07-19-2019, 09:24 PM   #3
detroitm2
detroitm2's Avatar
Drives: 2018 M2
2018 BMW M2  [0.00]
The M2 doesn't have studs from the factory.
The OEM lugs are not recommended for use with any size spacers. Fortunately most spacers come with extended lugs.
      07-20-2019, 01:30 AM   #4
Anthony1s
756
Drives: 2018 Mineral Grey M2
I think what he was asking is if you need longer studs (when doing a stud conversion) to fit spacers.
As long as the nut tightens all the way onto the stud, you are good. The nut is open-ended and needs to have the stud end pass through it. No threads exposed in the nut. There is a point when you do need longer studs, but not sure where that point is.
Appreciate 2
detroitm22427.50
      07-20-2019, 01:49 PM   #5
2PUTT
513
Drives: F87
the 82mm studs i got from Rogue allows up to 12mm spacers.
https://www.rogueengineering.com/Rog...tud_p_135.html
m2
