Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin M340i leaking coolant?
      07-17-2019, 07:24 PM   #1
Weiner0123
Weiner0123's Avatar
417
Drives: 2020 m340i. 2013 328i
Hey guys, so I just am a bit worried the other day I noticed a bunch of dried up white spots all over my drivers front rim and I had no idea what it was, so after a oil change today I was looking under the hood and found the coolant reservoir full of these white dots I found on the rim, also there's some dried coolant around it, Anyone have this ?? I attached the video aswell
      07-17-2019, 08:53 PM   #2
themnmd
themnmd's Avatar
Drives: 23 X5MC
Looks like a leak better have dealer check it out. May be hard to spot unless cooling system is under pressure
      02-24-2020, 10:56 PM   #3
Jenny8675
Jenny8675
Drives: G20
Late to this thread-I have noticed the same residue on my coolant cap. The dealer said it was from when they "topped it off" while they were repairing my transmission ( they had to take out the transmission and replace a seal and bolts after it started leaking fluid at 10k miles). The coolant issue seems to be residue that leaked and not a spill or overflow from when they "topped" it off.
Any tips on how to get the dealer to actually pressure test or look at the car without brushing me off? I already have a case with BMW NA to try to repurchase/replace because of constant issues.
      01-31-2023, 01:03 PM   #4
bimmerboy71195
bimmerboy71195's Avatar
68
Drives: alpine white 340xi
Does anyone know the correct psi for the coolant system?
g20
