07-17-2019, 12:03 PM | #1 |
1320
Rep 1,134
Coilovers?
What benefit would I get from installing coilovers on my car if I don't want to change the ride height or camber? What other benefits can I get?
07-17-2019, 11:45 PM | #2 |
5886
Rep 10,256
Coilovers offer two major benefits:
- Springs and shocks matched by design - Adjustable compression and rebound controls (some brands and models) If you want to maintain the OEM suspension height, the list of coilovers option is shorter. |
alohasurftoad3081.50 |
07-18-2019, 01:09 PM | #3 | |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Adjustables aren't of much value either IMO, because you don't know what the damping curves look like, or what spring rates pair best with the various curves with your vehicle's weight. A lot of coilovers can make you "feel" sportier (typically by over damping), but don't really increase grip/actual speed. Of course if you're willing to do a lot of work yourself by testing different springs and settings to optimize smoothness then it could be worth it, but I reckon fewer people do that than take their cars to the track. For about the same price as a good/high quality set of coilovers with independent compression/rebound adjustments you can get a bespoke setup from a tuner that will optimize the dampers (need a donor set) to whatever spring rates you want, your style of driving, and vehicle weight.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 07-18-2019 at 02:07 PM.. |
07-20-2019, 12:34 PM | #4 | ||
993
Rep 1,934
They'd still be adjustable, in height, at the minimum. In any case, OP, purchasing coilovers would give youoptions. You want the car lower, you can do that. You want them softer for a road tip, you can do that. You want them firmed up for a spirited drive or the track? You can do that. Whether the price for those options is worth it to someone is completely subjective, but the objective truth is that they are far better in every aspect than purchasing shocks with a set of springs. Unless you calculate the best spring rate for said shocks, and your car's weight, but then at that point you did all that work for no post-adjustability. May as well have went coilovers from the jump as that calculation is already dome for you. Coilovers that will keep your oem height, are indeed scarce. There's only the KW street comfort @ ~$1600 USD. Then the Bilstein StreetKomfort, IF YOU CAN FIND THEM,are near ~$2200 USD. Bilsteins PSS10 is superior in dynamics than the KW, but the KW is a lot more readily available, but people say they don't really go high enough in the rear. Thats the general consensus for all of the KW Vs though.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
07-20-2019, 01:00 PM | #5 | ||
4017
Rep 3,540
Or if you look at something even more "high quality" like Ohlins, they claim they only developed them on a 4cyl 320d car (and this is why some people who have 6cyl have been changing the front springs from 60N/mm to 80N/mm, because out of the box it's not optimized for their vehicles). Coilovers will give you more adjustability, but you won't necessarily know what optimal is. There are plenty of coilovers that won't tell you what spring rates they even come with, and no coilover manufacturer will tell you what ride frequencies you end up with from what I've seen.
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
07-20-2019, 09:18 PM | #6 |
1320
Rep 1,134
Thank you guys! Very informative. Decided not to get the coilovers simply because it sounds like the OEM setup is a good combination of comfort and sportiness and it is esthetically perfect to me. Thank you
07-22-2019, 05:39 PM | #7 | |
78
Rep 109
the drop I had is less than 1cm... |
07-22-2019, 08:57 PM | #8 | |||
993
Rep 1,934
Maybe Ohlins was lazier, but not every manufacturer will do that. In any case they may provide you the same exact shock because they are adjustable and when you adjust the dampening/rebound you are essentially adjusting the valving. None of the good coilovers will provide the exact same springs for different weighted cars. Maybe the 3-400 JOM and FK coilovers,but not kw or bilstein, or BC.
cfm56d7b5886.00 |
07-22-2019, 09:34 PM | #9 | |
4528
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
I have a 335i xdrive. I got a set of springs and dampers that were tested together by the damper manufacturer. I installed Eibach springs with Koni Special Active dampers. The Eibach springs slightly lower the car and eliminate some of the reverse rake built into the xdrive where the front wheel gap is greater than the rear. The Eibach drop is 0.8" and rear drop is 0.6". The Koni Special Active is like a passive version of the BMW adaptive dampers. It was developed with McLaren. The dampers have two valves tuned to separate frequencies. One frequency responds to rough roads and the other to spirited driving. The combination of the Eibach springs and Koni Special Active dampers provides a much more comfortable ride that doesn't rattle your teeth when you hit potholes or road seams. Yet when you attack an on or off ramp it tightens up and handles curves beautifully. It's a great combination by design since they were tested together by Koni North America. Hope this helps! |
rcaso26331.00 |
07-22-2019, 11:38 PM | #10 | |
4017
Rep 3,540
