BMW 5-Series (G30) Forum Engine, Exhaust, Drivetrain, Tuning Modifications Need some advice in stock exhaust sensor
      07-17-2019, 12:01 AM   #1
YoungOG08
YoungOG08's Avatar
Drives: 2018 540XI
Hey Guys, Today I went to the shop to install my M Performance Exhaust however when the mechanic seen the sensor on the stock exhaust he backed off cause he was afraid removing the sensor would trigger the check engine light the M Performance Exhaust doesn't come with this sensor or plug can you guys give me advice on this situation thank you below I included the picture of the sensor
      07-17-2019, 06:36 AM   #2
Bimmertrashjr
119
Drives: 2012 535i
Those are the valve actuators. Disconnect battery and swap them from stock to upgraded exhaust. At least that is what I did on my Dinan exhaust.
      07-17-2019, 07:26 AM   #3
AddyDaddy
AddyDaddy's Avatar
Drives: i5 M60, M5's, 535.335, M550i
There is a red 7.5 fuse in trunk fuse box you can pull to cut power to the flap. Surprised the mechanic didn't know that was the flap actuator.
Question is, what do they do with the 2 flap motors and wiring in case going back to stock is needed?
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M ,
2013 M5 , Individual Silver, Bolt ons-Straight piped
2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete
2024 i5 M60 Cape York Green
      07-18-2019, 12:42 AM   #4
YoungOG08
YoungOG08's Avatar
Drives: 2018 540XI
I just realized that the M Performance Exhaust brings a dummy Plug so I can disconnect the one attached to the stock exhaust and connect the dummy
clee1982797.50
      07-18-2019, 12:46 AM   #5
YoungOG08
YoungOG08's Avatar
Drives: 2018 540XI
The MPE came with a dummy sensor to connect when you disconnect the stock sensor
clee1982797.50
      07-18-2019, 05:52 AM   #6
Bimmertrashjr
119
Drives: 2012 535i
I'm not trying to bash the shop that was going to do the work, however you might want to use someone else. Hard to believe a competent/skilled exhaust shop wouldn't know what the actuators were.
      07-19-2019, 01:12 AM   #7
YoungOG08
YoungOG08's Avatar
Drives: 2018 540XI
Couldn't agree more with you
5post
