06-10-2019, 03:51 PM | #1 |
7610
Rep 3,427
S58 Engine Technical Document
Featured on BIMMERPOST.com S58 Engine Complete Vehicle Technical Document Also see: S58 Engine: Specs and First Look |
9
07-16-2019, 08:10 AM | #2 |
///M
6651
Rep 3,683
Thank you!
I wish they will add electric turbo to spool the low RPM. Maybe next generation
Life is too short...enjoy your life
///M |
07-16-2019, 09:22 AM | #4 |
Moderator
7509
Rep 19,370
The column in the chart that lists 0-100 hm/h in 4.3s is clearly labeled "F80/F82" which means it is for the outgoing/current generation models. This information is used only as a basis for comparison to the new X3/X4 M. There is no performance data available for the G8x M3/M4 yet.
07-16-2019, 10:09 AM | #5 |
BimmerPost Supporting Vendor
10776
Rep 27,588
nice
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
07-16-2019, 10:13 AM | #6 |
455
Rep 182
Drives: BMW M440i
I'm not sure if I missed something, but is there any information regarding CO2 emissions for these new engines?
Belgium adds a tax based on the CO2 emissions of the engine, which amounts to around €5k for the F8x. |
07-16-2019, 11:10 AM | #9 |
Moderator
7509
Rep 19,370
It's not necessary to hit 500hp with this engine. And the last thing people want is another maintenance item to think about, even just filling up a tank with water.
Perhaps a future M4 CSL will take advantage of water injection to boost output up to around 600hp. |
07-16-2019, 11:10 AM | #10 |
433
Rep 600
Drives: TiAg e91, r53 Cooper S, e28 M5
Says that it's ULEV 70... don't know how that translates for your country's specific laws... but I know it shows be "greener" than the outgoing model
07-16-2019, 11:31 AM | #11 |
1996
Rep 2,499
Maximum engine speeds of "the S58 up to 7500rpm." On cars with torque converters, the engine speeds will be limited to 7200rpm. So it seems they at least designed this engine to mate with a manual transmission. Hopefully...
07-16-2019, 11:39 AM | #12 |
1937
Rep 3,297
This is so lit
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams, CarbonStrucktureAnthracite, CF_Everything BMWPhotoVin, 01of01, GTS DCT, EPS, MDM, CS EDC,Analog Dip ,GTS parts. Euro Vin e30 M3, FIA cage / 14.7 p / w ratio. Euro E30 touring G30 MSport i3s LBB X5M 3.2carrera https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA |
Taco_Bueno955.50 |
07-16-2019, 11:39 AM | #13 | |
1937
Rep 3,297
This truly ' hybrid ' or mix
07-16-2019, 11:50 AM | #14 |
193
Rep 666
Looks like a solid engine. However, disabling piston oiling in favor for fuel efficiency worries me a little. The dual HPFPs and mechanical water pump are huge plusses in my book!
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
Brake_Late1936.50 |
07-16-2019, 12:02 PM | #15 |
514
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
Pretty cool they had the room to fit the intake box on top of the engine, although it makes me wonder if any additional turbo lag is noticed with the amount of intake piping for this engine (vs. the B58).
Seems they also moved the powerband up in the RPM range a bit vs. the S55; about ~500-700 RPM. I wonder how that'll make it "feel" below 2500 RPM vs. the outgoing M3/M4.
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
Brake_Late1936.50 |
07-16-2019, 12:16 PM | #16 | |
138
Rep 181
07-16-2019, 12:22 PM | #17 | |
1996
Rep 2,499
It's probably because they are using larger turbochargers for more power. There's no way of getting around bigger turbos for more power leading to turbo lag. That's why something like a McLaren has a lot of turbo lag and a car like the BMW 330i does not. |
dezzracer1182.50 |
07-16-2019, 01:13 PM | #18 | ||
514
Rep 1,055
Good point on the bigger turbo vs lag but according to the document: "The S58 engine has a twin-turbocharger system using mono-scroll turbochargers as also used on the S55 engine." (pg 69). Leads me to think the turbos aren't too different between S55 & S58.
07-16-2019, 01:20 PM | #20 |
109
Rep 1,043
What does the lower compression ratio tell us?
19 Audi RS5
15 Audi S5 GIAC Stage 2 white 11 E92 335is DCT FBO 441 whp silver 08 E92 335i FBO 6MT 427 whp space grey 05 E46 M3 red |
07-16-2019, 01:32 PM | #21 |
1316
Rep 2,349
More lag and less power off-boost, but potential for higher boost levels
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
