BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) ► Brake Pads & Rotor Options
      07-14-2019, 09:50 PM   #1
hl0m4n
hl0m4n's Avatar
Drives: BMW
Question ► Brake Pads & Rotor Options
if you search for x1 brake pads & rotors, the options are very limited besides oem.
however, comparison of oem parts show same fitment on mini. if this is the case, there are many alternative pads & rotor options available from mini but i am unsure of fitment.
can anyone verify if the parts are indeed interchangeable with mini counter part?
Cars: 07 335i ► 08 328i ► 11 328xi ► 13 M3 ► 17 M4 ► 14 M6
      07-15-2019, 04:45 PM   #2
x1x1x1
x1x1x1's Avatar
Drives: 2018 X1
2018 BMW X1  [0.00]
I noticed this when looking up cold air intakes. The K&N one was for the mini but fit the X1.
      07-29-2019, 07:20 PM   #3
fongpei
Drives: 2016 X1
Brake Sensor Reset Unsuccessful
I got a set of Akebono pads and can't reset the sensor light. Takes me through the process, then gives me a Reset Unsuccessful message. Do I need to short the sensor first as it states in other forums?
      07-29-2019, 08:53 PM   #4
Skyline2.0
137
Drives: 2018 BMW X1 xDrive
The brake sensors should be changed along with the pads, per BMW service manual. Links:
1. https://www.newtis.info/tisv2/a/en/f...rakes/BxzMXJ9s
2. https://www.newtis.info/tisv2/a/en/f...tor/1VnYFZgee9
I wouldn't recommend reusing the existing brake sensors if you decide to go through with brake pad replacement.
wcs2229170.50
xbimmers
