07-14-2019, 10:25 AM | #1 |
18
Rep 39
Drives: BMW 340iX 6MT Msport
Unhappy with BMS intake sound...
anyone else have this “issue” it’s a little too high pitched of a whoosh, I think. Does anyone make a replacement heat shield or box that has been tuned for better sound?
Im going to assume the filet and connector are somewhat interchangeable in terms of performance by the brands but the enclosures may provide different sound properties. |
07-14-2019, 12:23 PM | #2 |
11
Rep 60
Well this is a first. Usually some say it's not enough. I haven't seen covers but just different intakes instead. Dinan is closed as well as the new injen and afe
07-14-2019, 10:26 PM | #3 |
18
Rep 39
Not enough woosh? sure i can see that, but the tone is a bit high when it’s heard.
07-14-2019, 10:40 PM | #4 |
550
Rep 949
I've tried a few F chassis intakes and they all sounded the same to me. I like how the BMS is plastic as it stays cooler than metal and the filter has a lot of surface area. Maybe try adding cardboard around it to see if you can make any difference then have a sheet metal piece made?
07-15-2019, 08:12 AM | #5 |
1646
Rep 4,877
That's the sound of the intake on that engine as the turbo spools (regardless of what CAI you install). If you don't like the sound, I'd recommend going back to the stock airbox as they have all the resonators, etc to muffle that.
07-15-2019, 12:05 PM | #6 |
BimmerPost Supporting Vendor
24199
Rep 190,807
I personally like the open intake sound but it sounds like a closed intake is the better option for you OP.
We carry Dinan and AFE closed intakes if you are interested in replacing your current setup
07-19-2019, 12:55 AM | #7 |
18
Rep 39
Thanks i’ll take a look!
07-19-2019, 11:06 AM | #8 |
24199
Rep 190,807
07-20-2019, 09:41 AM | #9 |
473
Rep 931
Don’t like open intakes. Dirt gets inside the motor and engine bay heat. It also doesn’t see pressurized air coming in from the front like the closed intakes do which helps turbos out.
