Bimmerpost
4 Series
Technical Topics Wheels and Tires Does the M340i have enough tire?
      07-10-2019, 12:21 PM   #1
Giggler
408
Drives: 20' M340i, 24' X5 40i
I just picked up my M340i RWD and have it outfitted with the 19" rim and Pirelli P-Zero performance run-flat.
I have only done a few foot stomps (freeway metering light onramps) to get familiar with the driving dynamics but I instantly thought to myself the 255 rear tire was barely keeping its composure with all the available torque.
I'm wondering if other M340i drivers are feeling like a slightly wider tire might do better, and if so, what are you looking for?
My old 2011 Lexus IS-F has a 255 rear tire and the OEM rim could fit a 275 wide tire... the wider tire had a huge benefit off the line and in the corners. So I'm looking to try the same thing. Thoughts and opinions?
      07-11-2019, 02:30 AM   #2
Brett240
Brett240's Avatar
39
Drives: G20 330i
i'd go to a 10 inch rim for a 275 tyre, might be a bit baggy otherwise. what does the M340i have? 8.5 or 9?
      07-11-2019, 04:42 PM   #3
tnsatbhs
tnsatbhs's Avatar
Drives: 2020 BMW M340i xDrive
The rears are 8.5 and fronts 8
      07-11-2019, 08:24 PM   #4
Brett240
Brett240's Avatar
39
Drives: G20 330i
its probably doomed to run 255's then.
if you cant get a wider rim then a set of Ps$s non-run flats would be better than pirelli run flats in terms of grip
      07-13-2019, 05:28 AM   #5
Giggler
408
I’m thinking the upgrade from Pzero to the Pilot Sport 4 might do the trick for that extra little bit of grip.
g20
