07-10-2019, 11:00 PM | #2 |
80
Rep 241
On the driver side (LHD), when you pop the hood up, there's a black grommet covering a hole in the firewall. Shine a light in that corner of the engine bay and you will see it. Remove that grommet piece by peeling it off the firewall. Either make an X slit in the grommet, or drill a hole in the grommet, big enough to fit the OBD cable through. Once the cable is pulled through and passed into the engine side of the car, replace the grommet back into the firewall.
07-11-2019, 04:22 AM | #3 |
Rep 6
[QUOTE=808X1;25013879]On the driver side (LHD), when you pop the hood up, there's a black grommet covering a hole in the firewall. Shine a light in that corner of the engine bay and you will see it. Remove that grommet piece by peeling it off the firewall. Either make an X slit in the grommet, or drill a hole in the grommet, big enough to fit the OBD cable through. Once the cable is pulled through and passed into the engine side of the car, replace the grommet back into the firewall.[/QUOTE
Thank you my car is RHD unfortunately but I’ll still try |
