07-06-2019, 02:51 AM | #1 |
137
Rep 504
Disc brakes look rusty is this normal ?
Is it normal that the disc brakes the circle thing (lol) looks rusty all around (full coverage) while others ones have rusty spots etc. if it's normal I'll take pic and upload but if it is then why does have rust seems somethings wrong
07-06-2019, 04:09 AM | #2 |
49
Rep 107
I have noticed that after the car wash, the discs are rusty all around but only after a short drive, these return back to normal (shiny) appearance. I was concerned when I saw the rust for the first time but haven't been since.
nakamuru136.50 |
07-06-2019, 08:52 AM | #4 |
3107
Rep 3,072
Drives: 2023 iX M60 Oxide
I found this photo from elsewhere on the internet, showing what "bad" rotor rust looks like, basically interfering with the shiny surface area. This happens when a rotor sits for months and rusts, and the surface of the rotor gets deep rust scars that don't get contact with the pad while braking.
[IMG]https://i.stack.imgur.com/MZZLS.jpg[/IMG] Otherwise, wet rotors can build up a superficial rust literally overnight simply because they're mostly iron. Totally normal and wipes off immediately with use. Rust is a function of material, humidity, and temperature. Don't worry about spots vs film if the brakes are getting used every day, it's going to vary based on the water in the air or contact water and these other things on any given day. Only pay attention to what the rotors look like immediately after use. If they show pitting with valleys of rust like the photo above then they may need to be replaced. |
nakamuru136.50 |
07-06-2019, 09:50 AM | #5 | |
137
Rep 504
07-06-2019, 05:21 PM | #7 | ||
3107
Rep 3,072
07-06-2019, 05:35 PM | #8 |
137
Rep 504
that won't happen as I'll be driving my work car and then the x3 on weekends, hikes, camping etc.. so that should be ok right. Seattle rains a lot so at most i'll be leaving it around 7 days
