07-05-2019, 11:38 AM | #1 |
195
Rep 312
Drives: 2019 x3 M40i
x3 alignment question
So, my front tires are almost toast due to the corners being really worn on the outside. center tread is plenty and the rear tires have ample tread left at ~14k miles. a while ago my dealer did the oil change and convinced me to do the alignment to stave off exactly what is happening now as it was beginning to show at that point. Well they either didn't do it, or the stock spec isn't good enough as it has gotten worse and I need to consider new rubber soon.
Dealer wont do anything as they said its impossible to keep the alignment in check forever and they do not warranty the service. I called a local shop and they said they couldn't do it, or rather they could do the mechanicals but there is apparently coding required or some electronic adjustments that must be done. First I've heard of this on the X3, so does anyone have insight to if I can just go anywhere and get it done right or if I DO have to keep with the dealer and sit on them till its right? it looks like I just need less camber or maybe a touch of toe adjustment. |
07-05-2019, 11:57 AM | #2 |
Rep 8
The x3 needs a special order part for camber adjustment if it’s outside a certain range. A knuckle with something like a half degree bias can be installed. BMW does not give the tech a way to tweek camber otherwise is my understanding.
07-05-2019, 07:18 PM | #3 |
Head Idiot
251
Rep 551
See this thread: https://www.bimmerfest.com/forums/sh....php?t=1334213
I assume your tires are properly inflated, as underinflation can cause what you're seeing. Depending upon how one drives, some people have had tires last only 15-20K miles. |
07-05-2019, 08:09 PM | #4 |
806
Rep 1,906
A good alignment shop should be able to align the car. Coding, hmm....news to me; not required on my older F25; seems odd to 'code' unless car has some electronic sensors on the suspension.
The only readily available mechanical adjustment (I.e. no add'l parts) on the front of Bimmers is toe; incorrect toe will cause the issue you've seen on outer tire edges. My guess is the camber is within spec but obviously shop can check / verify values. I've never owned a new BMW, so no experience with Dealers Good luck /Bill |
07-06-2019, 08:57 AM | #6 | |
10995
Rep 32,881
07-06-2019, 09:06 AM | #7 |
3107
Rep 3,072
Drives: 2023 iX M60 Oxide
My tires are the same, they're not due for replacement yet, I'm at about half your mileage, but I can tell the front are worn a bit more on the outside only.
I thought this was normal, from the front tires taking the brunt of the pressure on the outside during cornering, and part of why tires are rotated. However, with my tires and staggered setup I can't rotate. Maybe there isn't enough camber tuned in to compensate. I usually don't get more than 20-25k out of a good tire anyway, the same compounds that remain soft in cold weather tires or for performance tires don't also usually last 30k+. When I have been able to rotate I can stretch to three years between sets, otherwise it's usually two years between sets. |
07-06-2019, 11:06 AM | #8 |
170
Rep 445
Drives: 2018 X3 M40i
Location: Milky Way, Earth, North America, Arizona more specifically.
Funny I have the SAME issue as op, at 15K miles and the front tires are worn on the outside, as well as the inside shoulders. The rears are wearing perfectly flat and may have another 10K on them.
Usually a sign of underinflation on the front wear yes, but I’ve kept mine at around 42 psi the whole time. Was going to take it into the dealer before I get new tires and have them zero the toe on the front. Some rear toe in is what you want anyway, and minimal to no front toe. |
07-06-2019, 11:36 AM | #9 | |
10995
Rep 32,881
07-09-2019, 04:55 PM | #10 |
195
Rep 312
yes, but I can't see how that would be affected by the alignment.
just outer edge, inner is like the rest of the tire. I'm slightly overinflating them for the time being to try and get more central wear and potentially prevent the tire from rolling over more and taking more off the edge |
07-09-2019, 05:20 PM | #11 | |
195
Rep 312
