07-04-2019, 05:41 PM | #2 |
163
Rep 216
alohasurftoad3081.50 |
07-05-2019, 06:22 AM | #3 | |
102
Rep 128
What I posted on the AUS Facebook page:
07-05-2019, 07:43 AM | #4 |
490
Rep 1,067
I installed the CG Precision this week, couldn't be happier with it. Sounds like VRSF has some damage control to do.
07-05-2019, 09:44 AM | #5 |
1320
Rep 1,134
Thank you guys. It looks like I'm going with CG or ER.
07-05-2019, 01:08 PM | #6 |
1646
Rep 4,877
From a structure standpoint, since the "flex coupler" doesn't flex, there isn't really a need for the hanger bracket. The DP bolts firmly to the turbo, and to the mid-pipe which has a bracket/nut to secure it to the body. If the flex coupler was as mobile as the OEM, then you would need that extra bracket to prevent the DP from flopping around. That being said, I'm unclear on why there is that "flex" coupler on the VSRF DP since it's 100% rigid.
When I installed it on my 340xi, it needs to be tweaked about an inch at the outlet side of the DP (right now it's mashed up against the tunnel brace and I'm waiting for VSRF to get back to me about the pictures I sent). |
07-07-2019, 09:33 AM | #7 | |
102
Rep 128
Being rigid, all mid pipe and backbox movement would thus be transferred straight to the turbo/exhaust coupling. Hence the concern re: no bracket and potential cracking of the turbo flange, which my exhaust installer has seen on a number of N55’s. The DP on the B58 is even bigger and heavier, so I don’t believe my concerned is unwarranted. Tiago couldn’t allay my concerns as he never bothered to talk technical to me. It’s simply not good engineering. |
drivef30111.00 alohasurftoad3081.50 |
07-08-2019, 11:21 AM | #8 |
370
Rep 552
I will say that when I had my CG DP installed on my N55, the bracket was completely off and could not be used/mounted. Almost as if it were welded in the wrong place. Been running it for a couple months with zero issues though and mechanics did not see this as a concern.
07-18-2019, 11:45 PM | #11 |
2466
Rep 5,457
Drives: F30
VRSF is known to have fitment issues on all engines available with F30 platform. Its very hit or miss doing business with them. Why risk it?
07-20-2019, 10:58 AM | #12 |
1646
Rep 4,877
I contacted VSRF and they requested I pull mine off my 340 and send it back for inspection/refund.
I replaced it with a ER one that slide in perfectly, with no issues. The ER's "flex" coupling isn't as sloppy as OEM, but does move with a little hand pressure. Interesting differences though: VSRF has a 5", 200 cell cat. Once installed, sounds change isn't a whole lot different than OEM. Maybe 10-20%? ER has a 4", 200 cell cat. Exhaust has a crisp raspy note. I would have expect the opposite with the cat sizes. I did have CEL errors for the second O2 sensor (BM3, stage 2 flash) when outside temps started to increase. I haven't had any yet on the ER, but it has been quite cool and rainy since I put it on. Smaller cat might address this. |
07-24-2019, 01:42 AM | #13 | ||||||
2095
Rep 43,350
"Hello, I’ve been having an issue with my downpipe. At 2.5k it’ll do a loud resonating, sort of like a civic sound exhaust noise (lol). After 3k it’ll go away but it’s pretty annoying. This shop named xxx installed it and said the the flex section was too stiff, any ideas?" Quote:
We've sold literally thousands of downpipes without the bracket across the N20, N54, N55, S55 and B58 platforms with absolutely zero negative consequences. Please stop spreading your mis-informed, unsubstantiated opinion as if you are qualified to do so. We have over 30 years of combined engineering experience between us over at VRSF. While you are entitled to your opinion, you should refrain from spreading BS until you can back your claims with facts. Quote:
Any popular vendor on this forum will gladly tell you this product will fit without issue. |
PURE340i104.00 |
07-24-2019, 10:27 PM | #16 |
187
Rep 1,103
I've yet to began tuning mods on my B58 but I installed and reviewed one of the earliest sets of N54 downpipes.
Ran them for 7yrs without issue. Now if I could just get them to make products for my Raptor Hint hint Tiago@VRSF |
07-25-2019, 12:23 AM | #17 | |
2095
Rep 43,350
janea120728.50 |
