07-04-2019, 11:16 AM | #1 |
379
Rep 544
Mirrortap problems.
Trying to get Mirrortap done. Installed as instructed. Does not work. Noticed it doesn't go into my Radenso Pro M like the standard plug. Pic below. Mirrortap on left, stock plug on right. Did they send me the wrong plug?
07-04-2019, 11:59 AM | #2 |
4079
Rep 5,235
Let me check mine. Give me a second
07-04-2019, 12:02 PM | #3 |
4079
Rep 5,235
Same plug I have on my mirrortap; juts a bit but works fine. I suspect the connections into the mirror may be loose. I had to use a little electric tape to hold in place.
07-04-2019, 12:19 PM | #4 |
379
Rep 544
Ok thanx. Back to the drawing board. I finally got the big piece off but don’t see how to remove the other two pieces so I can get a better view of the plug. Can’t seem to unplug it either (do you squeeze sides)? I jammed the appropriate taps into what appear to be the red and brown wire areas but looking at it from the side so obviously one or both not making contact. Will keep working at it.
07-04-2019, 03:42 PM | #7 |
94
Rep 419
Drives: 2019 F90 M5B, 2006 E60 550i
Speaking of the service ppl screwing with the power connection. I used to have my a Valentine One powered in that area on both my E39 and E60 and when serviced, they would always disconnect the setup. I finally got tired of it and just ended up selling the V1. Turns out that I never got caught anyway and didn’t really miss it.
07-04-2019, 07:04 PM | #8 |
257
Rep 495
I had a hell of a time with mine too. Find the install instructions here somewhere and the lower pieces take some strength to get off. The connector will come off if you use a small screwdriver on one side and pull the other at the same time. Two very tight very small tabs hold it in place. Make sure the plugs have a good connection before putting plastic back mine slipped out and I had to do it twice!
The plug is right it is slightly larger than the stock one it sits out like half way. Seems like it wouldn't work but it does. Good luck and have patience! |
07-06-2019, 06:22 PM | #9 | |
379
Rep 544
