BMW M5 F90 (2018+) General Forums Regional Forums USA - California    NO BMW TAX - SSR Performance - Parts, Installs, Tunes - SoCal's Trusted BMW Facility
Closed Thread
      07-01-2019, 07:38 PM   #1
SSR Performance
SSR Performance's Avatar
Drives: S55 -F80 / N54 -135i / N55-535
Smile NO BMW TAX - SSR Performance - Parts, Installs, Tunes - SoCal's Trusted BMW Facility
CHECKOUT WHAT WE'RE UP TO TODAY: instagram.com/SSRPerformance
A FEW BULLET POINTS...
• Forget the so called "BMW Tax", we will never overcharge for our work. A fair price is our promise to our customers..
• Brand new facility in the heart of Orange County (located just a minute away from Crevier BMW)
• Our knowledgeable and caring staff will make sure your car is handled with the highest quality and care in the industry (just ask any of our previous customers!)
• Our 5 Star rating across the board speaks for itself...
[center]
SUSPENSION
F90 M5 H&R Sport Springs (28686-1)
Front Lowering: 1.2"
Rear Lowering: 1.2"
This kit is designed for those who are looking for a very subtle drop from stock. (refer to images below)
MSRP $589
Install $550
Total: $1139
Our special price $949 (includes springs and installation)
M550i G30 H&R Springs (28721-2)
Front Lowering: 1.5"
Rear Lowering: 1.5"
Although these springs were initially designated from H&R as M550i springs, many F90 M5 drivers have adopted this application on their F90 M5's and found great success in a more aggressive drop and also minimal change in ride quality from stock. This kit can be direct swapped into your F90 M5 without any changes (just as the H&R kit that is designed for the F90 M5) however will yield a lower drop and a more aggressive stance for those looking to do so. (refer to images below)
MSRP $499
Install $550
Total: $1049
Our special price $899 (includes springs and installation)
F90 M5 KW Height Adjustable Spring (HAS) (253200CC)
Front Lowering: 0.2" to 0.8"
Rear Lowering: 0.2" to 0.8"
If you are unsure of what height you are necessarily looking for and don't want to get stuck with a set of springs and then have to change then out again and pay full labor to do so then you will want to go with the KW Height Adjustable Springs. Just as the name suggests, the height is adjustable within the above given ranges and you can have them set to your preference at the time of installation. If you ever want to change the height you can do so by taking it into any local shop and having them adjust it within a matter of just about 1 hour.
MSRP $1350
Install $600
Total: $1950
Our special price $1699 (includes springs and installation)
SSR PERFORMANCE POWER PACK
SSR PERFORMANCE F90 M5 3" STAINLESS STEEL DOWNPIPES (2018+)
5 Reasons to buy SSR Performance downpipes:
- Every single set of downpipes is fitted to the same EXACT, proven, jig to guarantee, direct bolt-on, perfect fitment every time
- SSR downpipes are crafted using ONLY certified 304 Stainless Steel and are TIG welded by our Certified Professional TIG Welder right here in Orange County, CA
- Completely precision CNC machined mono-block lipless / stepless V-band flange design
- Developed and flow tested by our engineers directly on our shop F90 M5 to provide optimal flow and horsepower gains on the Dyno and on the Track
- No Hassle LIFETIME warranty
> CLICK HERE TO ORDER NOW <
UPGRADED PURE TURBOS
Here at SSR Performance we install / sell more Pure turbos than any other facility in the Southern California region! What does that mean? When your BMW is here at SSR Performance it will be done right and it will be done right the first time! We know and use all proper torque specs along with proper installation kits which are necessary when installing turbos. With that said, all o-rings, gaskets, and fluids necessary are replaced at the time of installation. We offer the same 1 year 10,000 mile warranty on all Pure turbo upgrades as we do with all other jobs here at SSR Performance. If you are looking to make some serious power out of your S63 engine then Pure Stage 2 turbos is the next upgrade for you!
[/left]
SERVICE AND MAINTENANCE
If you are looking for reputable and trustworthy maintenance work then look no further! From oil changes to brakes we have you covered! You can expect HIGHER than dealership level maintenance and repair work. We have the best customer service in the area for a reason, because WE CARE. We will always be here to answer your questions, we will stick to our deadlines and always ensure that your car leaves 100% better when it leaves our facility than when it comes in. We offer 100% free of charge full complimentary diagnosis on all vehicles! We would love to take care of your vehicle for you! The following is a list of the items that we can take care of for you:
-Walnut blast - Intake valve service
-Oil Change
-Rod Bearing service / replacement
-Coolant flush
-Transmission flush
-Differential flush
-Spark Plug replacement
-Fuel Injectors
-Valve cover gasket
-Oil filter housing gaskets
-Waterpump + thermostat
-Cabin filter
-Brakes/rotors
-Clutch/flywheel
-Battery
-Turbos
And much much more...
ABOUT US
Started in Southern California by Shah and Zayn, SSR Performance began as an aftermarket BMW parts manufacturer. With the Mechanical and Aerospace engineering backgrounds of both co-founders, designing parts was second nature. Along with the sale of parts came the undeniable need for a location to be able to install these parts. With over 10 years of combined automotive expertise between the founders, the decision was made to open SSR Performance's first location in beautiful Orange County, CA. Today SSR Performance is a thriving business that takes care of any and all aftermarket modifications, repairs, and upgrades on new model BMWs.
At SSR Performance you never have to worry about the "BMW tax". All of our services and installs are VERY reasonably priced with our customers in mind. We have some of the highest ratings on Yelp!, Google, and Facebook, for three reasons. We promise and deliver high quality, honesty, and uncanny customer support! When you bring us your vehicle we will make sure to take care of it as our own.
ABOUT OUR FACILITY
SSR Performance is a BMW full service and install facility with a 7,000 sq ft footprint! We are located in the heart of Orange County in Southern California. Our brand new facility includes a customer lounge with free WiFi, Xbox One (games and Netflix galore!), and free drinks / snacks. We are more than happy to have you hangout at the shop while we get your ride situated! We have a very open shop environment. You can rest assured that you will be able to watch and ask questions throughout your visit
WHAT WE OFFER
Service - From regular oil changes to brakes we can take care of all of your M3 and M4 servicing needs!
Repairs - We can handle all minor and major repairs
Parts / Installs - We can purchase your new exhausts, wheels, intakes, etc. AND have them installed for the best prices around! We know how much you love to mod your car. We're here to help!
Vehicle Wraps - We offer partial and full vehicle wraps! From chrome deletes to full color change wraps, we have it all!
WHERE WE ARE LOCATED
590 W Freedom Ave Orange, CA 92865
Contact Info: Please feel free to contact us for any questions that you may have!
Website: www.SSR-Performance.com
Email: info@SSR-Performance.com
Phone: (800) 438-2808
Instagram: @SSRperformance (follow us to stay updated!)
590 W Freedom Ave Orange, CA 92865 (open by appointment)
      07-01-2019, 08:12 PM   #2
SSR Performance
M550i H&R SPRINGS
Freshly installed a set of M550i lowering springs on the Zito F90 M5! This client chose the M550i lowering spring set from H&R as opposed to the kit that is made specifically for the F90 M5 because it has been discovered that this kit gives the car a more aggressive drop compared to the F90 M5 one. It can be seen here that this F90 M5 sits very nicely on these Zito wheels!
(wheel specs 20x10 ET25 front and 20x11 ET25)
We also happened to install a set of our competition downpipes on this beast to give it that extra roar and of course some real added horsepower!
Call us to order your set and schedule your appointment today!
(800) 438-2808 or info@SSR-Performance.com
      07-01-2019, 08:20 PM   #3
SSR Performance
The VF Engineering F90 M5 just got fitted with our F90 M5 Competition Series downpipes! These downpipes are made in the USA and have the best value on the market. Fit and finish is 100% every single time guaranteed. To add to that, these downpipes come with a lifetime warranty!
• Every single set of downpipes is fitted to the same EXACT, proven, jig to guarantee, direct bolt-on, perfect fitment every time
• SSR downpipes are crafted using ONLY certified 3 inch diameter 304 Stainless Steel and are TIG welded by our Certified Professional TIG Welder right here in Orange County, CA
• Completely precision CNC machined mono-block lipless / stepless V-band flange design
• Developed and flow tested by our engineers directly on our shop M3 and M4 to provide optimal flow and horsepower gains on the Dyno and on the Track
• No Hassle LIFETIME warranty (see below for details)
>CLICK HERE TO ORDER NOW<
      08-15-2019, 02:34 PM   #4
SSR Performance
Check out our YouTube channel and stay up to date on whats happening here at SSR Performance! We post weekly so make sure you subscribe.
You won't want to miss what we do next. It might just be your car. Call now to set up an appointment and maybe get your car featured on our channel!
(800) 438-2808
This week @ SSR Performance
We help make our clients dream a reality by creating a custom bespoke titanium exhaust for his McLaren 600LT. We show you the ins and outs of how we fabricate and design our titanium exhaust 100% in house.
We also discuss vehicle maintenance and why a rod bearing replacement job is so important to do, especially on your S65 and S85 engine. A friend stops by to get a tune and SSR downpipes for his Mercedes AMG GTR.
      08-29-2019, 04:16 PM   #5
SSR Performance
When was the last time you did your brake pads? How about the last time you checked your rotors? 😱 Theres no reason to wait! ENJOY 15% off on OEM brake pads and rotors! If you notice your brakes squeaking, shaking, or grinding it’s definitely time to give us a call! 📞 (800) 438-2808 We will be happy to help and get you on the road again with brand new brakes/rotors with 15% off! 🏁
(800) 438-2808
      09-10-2019, 02:06 PM   #6
SSR Performance
⚠️ LAST CHANCE FOR 10% OFF SPECIAL ON THE KW KIT! ⚠️
Available for all makes and models. Lower your car with one of the best lowering spring systems on the market! KW height adjustable springs kits are a great alternative to traditional lowering springs. You don't have to be satisfied with a fixed lowering range, with KW Height Adjustable Spring kits you can adjust the ride height with the KW height adjuster even after the kit has been installed!
Call us to claim the 10% off! ☎️ (800) 438-2808
      10-03-2019, 04:10 PM   #7
SSR Performance
Time to unleash the beast 😈 This is your first look at our brand new sound proof dyno cell built right here at our facility in Orange County, CA. We spent A LOT of time and effort making this happen for all of you! From now on all of our dyno tuning, testing, and R&D will be done right here under our roof on this AWD Mustang Dyno 🙌🏽 We are extremely excited to announce this new service and we want to give a HUGE thank you to all of you who have supported us from the very beginning 🙏🏼 As always.... stay tuned
      10-11-2019, 06:56 PM   #8
SSR Performance
Call us now to get your project started! We are more than happy to answer any and all questions that you may have.
Our goal is to get your car setup the way that you have always imagined!
(800) 438-2808
      11-15-2019, 02:04 PM   #9
SSR Performance
Today’s 2010 E92 M3 OEM Rod Bearings are out! This particular set wasn’t too bad for 92,568 miles on the clock. We’ve seen worse with 25,000 miles, but you should still get the Rod Bearings upgraded no matter how you drive your car! This applies to all S65 engines! If you happen to own an S65, this is a MUST NEED! Don’t wait till it’s too late. Simply give us a call today get started; our experts will be ready to assist you! ⚙️
PM us to get started today!
📞: +1 (800) 438-2808 (Mention your from the forum)
Text: 949-558-6307
      11-18-2019, 04:58 PM   #10
SSR Performance
Time to have some fun with this M2 Competition! 🏁 We are upgrading his turbos to Pureturbos Stage 2 Turbos and upgrading his CrankHub! 🙌 Boost weather is coming sooo....❄️😉
1 (800) 438-2808
      11-19-2019, 02:50 PM   #11
SSR Performance
VRSF Intercooler is about to get installed on this E90 335i for maximum cooling and performance! 💨 Gain more consistent power figures for longer periods of time ideal for racing.
PM or call us to get started today!
📞: (800) 438 -2808 (Say your from the forum and ask for Mark!)
Text: 949-558-6307
Closed Thread
Tags
bmw m5, deal, downpipe, dyno, f90, installation, socal, springs, ssr performance, suspension
