06-28-2019, 11:10 AM | #1 |
218
Rep 392
Any UK owners trusted Halford with dashcam install
I have had lots of positive feedback from friends and colleagues about installs but wondered if there is any forum experience?
06-28-2019, 11:26 AM | #3 |
70
Rep 213
Drives: BMW X5 30d
I was going to ask the same as looking into purchasing the Blackvue 750s dashcam, but I guess it all depends on the branch and person doing the install. My worry is you get some person that doesn't give a sh!t and installs it incorrectly or takes apart the trim and doesn't put it back properly.
06-28-2019, 11:46 AM | #4 | |
218
Rep 392
It’s like any trade if they are trained correctly and give a sh77 then they will do a great job. The branch about 20 miles from us has fitted a new battery to my mums car and wipers and always done a great job, also good reviews from friend and colleagues, Thinking if they are insured etc the risk is minimal, if I do it and airbags go off or electrical issues there is no come back but if they do it then I have some cover. |
06-28-2019, 11:50 AM | #5 |
363
Rep 912
I had my blackvue front and rear dash cam installed by them and they were excellent. The technician was very knowledgeable and it’s very nicely installed. I had a faulty power magic pro but they swapped it out straight away.
I’m sure it will be down to specific branches as to the quality but I can’t fault the service personally.
Current Black Sapphire X3M Comp LCI
Gone: X3 M40i BM3 / 330d M Sport PPK / 320 Efficient Dynamics / 123d MSport (Superchipped). |
HampshireUK218.00 |
06-28-2019, 11:58 AM | #6 |
70
Rep 213
Drives: BMW X5 30d
How much do they charge to install anyway?
I was looking at blackvuehd which essentially it TTW Installation which essentially deals with installs of in car equipment such as dash cam. Never used them but they advertise themselves as taking good care of your car and ensure there are no interference with DAB radio (of course they would). Called them and asked them price of X3 install and it was around £189, they do mobile install or you can drive to them. |
06-28-2019, 01:09 PM | #7 | |
218
Rep 392
Looks like about £50 for the install and cables, memory card etc |
06-29-2019, 10:10 AM | #8 |
363
Rep 912
It £50 for the install. Pretty reasonable. About 2 hours I think.
06-29-2019, 11:03 AM | #9 |
218
Rep 392
New model Nextbase 522GW dashcam at Halfords
£119 camera only without SD card £184 wiring kit, installation and 64 Gb SD card I might let them loose on the wife’s VW Tiguan first then decide if they can go near my X3 |
06-29-2019, 10:45 PM | #10 |
21
Rep 50
First had wifes i10 done. Front fuse box install. Finish ok had to push a few bits back to perfection. However when it rained found camera installed outside wiper sweep. Moved it myself. Then had my m40d done. Turned into a rear fuse box install, thought it was possible in front but hey. Result good. As a precaution had them use suction pad and give excess wire in case I wanted to move.
HampshireUK218.00 |
06-30-2019, 01:09 AM | #11 | |
218
Rep 392
06-30-2019, 01:43 AM | #12 | |
363
Rep 912
06-30-2019, 02:09 AM | #14 | |
709
Rep 1,696
Have an interest in this thread because I'm in the process of swapping my F31 for G01. Going forward though, may not hard wire into the car. May just run long cable to back of car and pick up one of 12 volt slots. Not sure yet. I do have some battery drain warnings quite regularly and in all the time I've had the parking mode on, I've never needed it. |
06-30-2019, 02:18 AM | #15 |
363
Rep 912
HampshireUK218.00 |
06-30-2019, 04:24 AM | #16 |
243
Rep 1,205
I used Blackvue themselves to install my last dash cam ... thinking their fitter would be great. Well, he wasn't, and having had the child like wiring shown to me by my alarm installer, I used them for the X3 Blackvue install. ... and am very pleased.
Road Radio from Crawley / Redhill were mine - £70 installed I think it was + properly. Not used Halfords but can't imagine they will be worse than Blackvue themselves , as an example !! |
06-30-2019, 05:16 AM | #17 | |
21
Rep 50
I have nextbase 422 with rear camera module added directly on. The rear is just ok, not really a full rear cam. |
06-30-2019, 05:22 AM | #18 |
214
Rep 538
I installed a Nextbase GW522 in to both mine and my wifes cars last week with the rear camera module in the back window. Its super easy to hide the wiring just watch a couple of your tube videos to give you ideas but basically its the same on any car. I used the nextbase wiring kit as well which you just remove a cigarette lighter fuse and pope the tap in there. Both cars used the front fuse box locations and were less than an hour each to fit.
I can thoroughly recommend the GW522 footage and sound is superb and you can control all the setting and download the footage straight to your phone. |
07-05-2019, 05:37 AM | #19 |
218
Rep 392
I had a Nextbase 512GW fitted at my local Halfords today in the wife’s VW Tiguan. The guy was knowledgable, polite and completed the job without damage or fuss in 30 mins. No sign of any wires and a good job.
He mentioned that Blackvue are better suited to BMW and Mercedes due to the potential for battery drain on the Nextbase cameras. |
07-05-2019, 02:52 PM | #20 | |
243
Rep 1,205
willjames709.00 |
07-05-2019, 07:11 PM | #21 |
214
Rep 538
The Nextbase cameras a great and can't drain the car battery even if faulty when they're wired in correctly. It should be wired into the cigarette light fuse which is disconnected power wise by the car after about 4 minutes with the ignition off. So the camera has no power feed after that, that's when it relies on its internal battery for parking mode. It's the power up and power down from that source that turns the camera on and off. Anyone who has problems with battery drain and the Nextbase cams has the incorrectly fitted. We have two on our BMWs and both work great.
07-06-2019, 02:41 AM | #22 | |
243
Rep 1,205
