06-27-2019, 01:41 PM | #1 |
218
Rep 392
TPMS oddness
After 7 months and 5500 miles I checked the tyre pressure yesterday with a trusted gauge and realised the dealer had set the pressure for a fully loaded car.. I decided to reduce pressure down about 2 bar per axle in an attempt to reduce centre tyre wear but maybe preserve edge wear.
Even though they were above the minimum label pressure I got a tyre warming when leaving work tonight? It’s been warm in the UK today and a reset resolved but odd. |
06-27-2019, 02:04 PM | #2 | ||
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,211
You have to RESET TPM after you change tire pressure. Your car did it's job by notifying you the tire pressure went down. |
06-27-2019, 02:09 PM | #3 |
218
Rep 392
06-27-2019, 02:18 PM | #4 | ||
3511
Rep 4,211
Just reset your TPM and everything will be fine |
06-27-2019, 03:23 PM | #5 |
218
Rep 392
Fair enough, odd though as I drove to work 24 miles this morning and no issues, car sat for 10 hours restarted and warning came up.
Have reset and hope no more gremlins |
06-27-2019, 03:28 PM | #6 |
10995
Rep 32,881
That’s normal, when I fitted my winter wheels without TPMS sensors it would take 10-20 miles before the warning would appear.
06-28-2019, 01:30 AM | #7 | |
218
Rep 392
The ride in comfort mode with the 21” wheels was already good IMHO but dropping 0.2 bar/3PSI has further improved ride and steering |
06-28-2019, 02:06 AM | #8 |
234
Rep 738
Have you selected what tyres you have within Idrive?
I have and my screen like yours also tells me what the front and rear pressures should be, which changes as the temperature goes up!
X3 M40i Carbon Black
06-28-2019, 03:29 AM | #9 | |
Straight Six Convert
444
Rep 894
Drives: 2019 X3 M40i
Shouldn’t it be 2.2 and 2.4 for partial load? Interested what people use to check pressure and inflate with, as I have a digital inflator that then doesn’t seem to tie in with what TPMS says. So contemplating getting a new Ring RTC6000 cordless Ring RTC6000 Compressor, Cordless Digital Inflator & Air Pump https://www.amazon.co.uk/dp/B07MVWDS..._4bDfDb6GJTKY9 |
06-28-2019, 05:03 AM | #10 | |
218
Rep 392
06-28-2019, 05:34 AM | #11 | |
444
Rep 894
2019 G01 X3 /// M40i in Carbon Black, 718M 21's, M Sport + Pack, Pano, F/Mirrors, Full Screen CarPlay Activated, ThinkWare F770 F/R DashCams, Gyeon Q2 Pure Ceramic Coated. PCW BackBox Mod
06-28-2019, 06:55 AM | #12 | |
218
Rep 392
Good spot, for some reason my dealer had set the tyre to a Special Authorisation size, maybe whoever did the PDI only noticed it displayed rear tyre sizes and gave up. It seems the partial load setting on the 21” tyres, it changes its mind what the ideal pressure should be though, the sticker says 2.2 front 2.4 rear. You will see from the pics it suggests more, then after a drive changes recommended pressure again I only weigh 72 KG so nothing to do with a heavy load Last edited by HampshireUK; 06-28-2019 at 07:05 AM.. |
06-28-2019, 07:43 AM | #13 |
234
Rep 738
I think the change is related to the tyre temperature, so it’s effectively a ‘live’ figure.
The figures on the sticker by the door are for cold tyres, so I’d expect them to be higher after a run
06-28-2019, 07:58 AM | #14 |
218
Rep 392
I don’t understand why the recommended pressures would change, I get the tyre pressure would change though
06-28-2019, 08:20 AM | #15 | |
444
Rep 894
